Rear High Clearance Bumper Build
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tweeek, Nov 11, 2013.
  1. Nov 19, 2013 at 7:11 PM
    Slimwood Shady
    Slimwood Shady I love your mom!
    Linwood
    San Antonio, TX
    '23 TRD Pro Tundra; 996TT; '16 Odyssey
    #nomods
    FYI, be sure to leave a decent gap under the tail light, if not, when the frame flexes, or if you drop off a rock onto it, it could flex up and brake the lights....
  2. Nov 19, 2013 at 7:13 PM
    tweeek
    tweeek [OP] Well-Known Member
    Victoria, BC
    2006 Tacoma Access Cab TRD OR
    Yup... I left about 1/2 - 5/8 on my front and it never rubs.. I will do the same in the rear.
    Thanks!
  3. Nov 19, 2013 at 7:15 PM
    Darth_Yota
    Darth_Yota I intend to live forever, or die trying.
    Cam-moron
    Somewhere USA
    Dented, broken-down ‘08 hoopty
    Ain’t good’nuff for insta
    :thumbsup: Lookin good!
  4. Nov 23, 2013 at 7:39 PM
    tweeek
    Victoria, BC
    Got a few more things done today. Fabbed the tire carrier portion of the tiregate. Also got the spindle welded in.
    y5apyvev_36d5a8ffb7eea3e23e4c2a1f6cbc1e15b11fe0ca.jpgquhabu7e_678d4244c4ccc071f2ac10a0550e43ab2c98665c.jpgavu8ahyv_6f65959d5cbfb292b2b9f4f6f565acb2e0d341bd.jpguqapa5av_9b8dfef0f592f60982294f8c76629e368629b671.jpg
    Going to get some gussets on tomorrow and finish the frame mounts.
  5. Nov 23, 2013 at 7:42 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Looks great so far. I'm excited to see the final product.
  6. Nov 24, 2013 at 7:51 PM
    AZ hunter
    AZ hunter Well-Known Member
    Kade
    Tucson
    '14 DCSB TRD OR
    Engine Mods: URD Cold Air Intake Interior Mods: Weathertech Floor Liners Exterior Mods: Plastidiped Emblems
    This is all kinds of bad ass. Sub'd!
  7. Nov 24, 2013 at 10:12 PM
    4x4Taco09
    4x4Taco09 Well-Known Member
    Dane
    Louisiana
    09 TRD Sport 4x4 BSP DC LB
    Kings, Deavers, Brute Force, Prinsu, Lights, all the stuff
    This is going to look sick! nice work
  8. Nov 24, 2013 at 10:25 PM
    Dusty taco
    Dusty taco Well-Known Member
    Eli
    NorCal
    05 DC SB 4X4 SR5
    Magnaflow 2.5" Exhaust, Satoshi Style Grill, Led floods behind Grill, Firestone ride-rite airbags (rear), blue sea fuse block. Custom bed bar with shovel mount and utility led lights
    Sub'd can't wait to see how it turns out
  9. Nov 27, 2013 at 10:00 AM
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Great progress! A few questions:
    • What did you use for the recovery points, it looks quite thick and I assume you did not cut the holes through it?
    • How did you cut the circle for the tire mount
    • What spindle it that?
  10. Nov 27, 2013 at 12:21 PM
    tweeek
    Victoria, BC
    The recovery points are just 2.5" by 3/4" flat bar. I trimmed the corners with a zip disc and drilled the center hole to 1" to accomodate a 3/4" shackle. I have a super duper wimpy and cheap drill press. It plowed through the 3/4 without issue as long as I kept it well lubed, went slow, and went up in 1/16 drill bit increments when I got above 5/8.
    As for the tire holder, I have a plasma cutter that I was fortunate enough to borrow from a coworker. You can buy a precut circle or go with a triangular design with corners ground/cut off if you didnt have access to a plasma though.
    The spindle is from Summit Machine. It is very nicely machined and VERY beefy.
    Im moving pretty slow as I usually have very little time during the week to get much done. I will hopefully knock off some more this weekend!
  11. Nov 27, 2013 at 1:36 PM
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Thanks for the info, keep up the good work!
  12. Dec 20, 2013 at 1:46 PM
    tweeek
    Victoria, BC
    I have been really bad about updating this thread, but I have been working on this in my spare time. Got quite a bit done.
    Got all the pieces cut for the 1/4 panels
    All tacked up
    Starting to grind things down
    I did decide to go dual swingout. The second spindle is welded in.
    Gussets for the swingarm
    superdenk likes this.
  13. Dec 20, 2013 at 3:04 PM
    Darth_Yota
    Cam-moron
    Somewhere USA
    Hot damn dood! That looks awesome!
  14. Dec 20, 2013 at 9:45 PM
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    Wow can you say STOUT
  15. Dec 20, 2013 at 10:07 PM
    #35
    Spoonman
    Jamie
    Alberta
    You have skills.
  16. Dec 21, 2013 at 8:59 AM
    #36
    TxFireman
    TxFireman Factory Pilot
    San Antonio, Texas
    2013 DC-SB TRD-OR, tow package, entune/nav
    Looks like it's coming along nicely. Great work!
  17. Dec 21, 2013 at 9:06 AM
    #37
    Ghost848
    Ghost848 Well-Known Member
    Tony
    Alberta,Canada
    09 V6 TRD OR Silver M6
    OME + Dakers, 285/75R16 Nitto Trail Grapplers, ARB Bumper, Columbia overland Dual battery, Super winch,CC stage 4 clutch, bestop supertop, URD TO bearing, BHLM headlights, Cruisin offroad rear bumper, Harrop front E-locker.
  18. Dec 21, 2013 at 10:34 AM
    #38
    tweeek
    Victoria, BC
    Ive seen yours, it is awesome! I ended up going duals but think I would have been okay either way. My only condition with going duals is that I can open the glass on the canopy with only the tire gate open. I dont think that is going to be a problem in my design.
    I actually bought both my spindles from Jason at Cruisin Offroad, he was fantastic to deal with. I am just over the pond on Vancouver Island :)
  19. Dec 21, 2013 at 10:37 AM
    #39
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    Damn das hot
  20. Dec 21, 2013 at 10:47 AM
    #40
    Manwithoutaplan
    ID
    does the tire shake at All?
