rear hub chirping?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kpla51, Sep 5, 2015.
  1. Sep 5, 2015 at 4:45 PM
    kpla51
    kpla51 [OP] Well-Known Member
    Fort Campbell
    Ok so this started about 3 weeks ago. While under slow acceleration in 1-2 i hear a chirping sound. Only happens under acceleration Ive wiggled the drive shaft for play in the u joints but it sounds like its coming from the driver rear tire. Could it be bad break pads? It doesn't do it in reverse ither. Any help would be great before I start tearing into her.
  2. Sep 6, 2015 at 5:14 PM
    kpla51
    Fort Campbell
    Ok so today I drove through a puddle and the noise stopped. It was on the way home so ill wait to see in the morning if the sound comes back.
  3. Sep 7, 2015 at 5:09 AM
    kpla51
    Fort Campbell
    ill try that. Thinking of it I was rolling into my garage at about 3am after work and for some dumb reason pulled the parking brake while still rolling even though i was moving extremely slow maybe thats the culprit? Maybe its an adjustment issue of the hand brake?
  4. Sep 7, 2015 at 7:45 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Pulling the drums is a good idea to inspect and clean. if nothing is found there i would be guessing maybe a universal joint. Wiggling the drive shaft while installed doesn't tell you much. Grease them up and see if it goes away for a while or pull out the shaft and inspect the u-joints.
    DoorDing likes this.
  5. Feb 18, 2022 at 4:07 PM
    Joraleigh
    Joraleigh Member
    Joe
    2012 Tacoma access cab TRD off road
    Hey OP what did it end up being? Mines doing the same. Stopped for a day after a car wash too.
