Rear leaf lift question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Clifford The Big Red Tacoma, Mar 7, 2016.
  1. Mar 7, 2016 at 2:17 PM
    Clifford The Big Red Tacoma [OP] Active Member
    RyNo
    Montpelier, Vermont
    2007 Radiant Red Base Access Cab 4x4
    6" Rough Country lift 35" mud tires Motto Metal 17" rims Alcan 5 1/2" lift springs Satoshi grill mod SOS Offroad (WIY) front bumper Custom made CB antenna bracket Cobra LTD Classic CB TPMS bypass delete mod Dynomax cat back exhaust Bed pocket lights mod Aries Off Road oversize mud flaps Wet Okeo seat covers Bushwacker pocket style fender flares Weathertech floor mats Rear diff breather relocation mod Rago Fabrication ditch light brackets LED cube ditch lights Alpine CD/DVD player with nav. High lift jack Black headlight mod Blue Seas auxiliary fuse box Blue Seas circuit breaker Custom made fuse box plate Led interior lights Debadged Under hood led light kit 4 piece rain gaurds Bug deflector Kobalt tool box Anytime fog light mod
    I have a 2007 Tacoma access cab that I installed a rough country 6" lift kit into. The the rear was lifted with 4" lift blocks. Well my problem is it sags like a mofo with no weight so I added a leaf and don't like the looks of it and I have vibrations up the a** which I have had since the lift install was complete. My question is who makes springs to accomplish 6" of lift in order to eliminate the leaf springs I have now and the lift blocks? I was told by Bill at
    Alcan Spring that they could build me a set of 6” lift springs for $730.00 with the bushings. So would I need 4" lift leaf springs or 6" lift leaf springs? I was told by another guy if you have a 6” lift in the front a 4” block in the rear that you need a 6” lift rear spring to get rid of the block and the adda leaf. Bill said that 6” lift springs for my truck will have 10” of free arch which I guess I don't understand what that means. Bill says that he thinks that if I were to have them build a 6” lift spring for the rear of my truck to match the 6” front lift that it should level me out and at the worst case scenario I may have a little rake to the front which is what I don't want. Any input or ideas or suggestions?
    Thanks
