Rear leaf packs
Discussion in '1st Gen. Tacomas (1995-2004)' started by milorsm1, May 10, 2013.
  1. May 10, 2013 at 10:07 AM
    milorsm1
    milorsm1 [OP] Active Member
    Robby
    Louisiana
    01 SR5 4x4 TRD
    Just upgraded to bilstein 5100s front and back
    Trying to remove rear leaf packs and can't get the bolt out close to gas tank. Anyone have a trick to tell me or do I need to drop tank to beat it out.
  2. May 10, 2013 at 11:38 AM
    TIPICOTACO
    TIPICOTACO Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
    had to use a cut off wheel on both my main eye bolts :(
    try to heat or freeze it yet?
  3. May 10, 2013 at 11:41 AM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    being close to the tank might be dangerous for heat. sawzall or maybe use a fire extinguisher to freeze it.
  4. May 10, 2013 at 11:43 AM
    Bmack04
    Bmack04 Active Member
    Ohio
    04 DC trd 4x4
    deck plate mod, grey wire mod, 5100s front w/OME 881s, 5100s rear w/wheelers 5 leaf, 265/75R16 Firestone Destination A/Ts
    Cut off wheel is what I used, be careful not to damage the frame bracket when cutting.
  5. May 10, 2013 at 11:57 AM
    blknblubkrdude
    blknblubkrdude Well-Known Member
    Gillette, WY
    96 Taco. 4X4, 5MT, 2.7
    Oil field truck with 250k miles...original powertain. Wheelers 881's/5-pack, Energy bushings throughout.
    If you use a powerful impact to spin the bolt, and use a large prybar on the threaded end of the bolt, it should come out. If you live in a rusty area, you're probably screwed regardless :)
  6. May 10, 2013 at 1:14 PM
    kmok
    kmok Plastidipped ma Hootus!
    Kyle
    Columbus, Ohio
    2005 Subaru Outback XT 5MT
    Took a sawzall and an air impact gun to get the damn thing off on my truck. Took many hours and lots of swearing lol
  7. May 10, 2013 at 1:17 PM
    CBR1000RR
    CBR1000RR Well-Known Member
    Maryland
    03 TRD DoubleCab
    Toytec ultimate lift kit
    I just did the lift on my truck and it was impossible to get that bolt out....I ended up just leaving it on and removing the rear and dropping the axle to do the AAL. When I replace the leaf packs I will be buying all new bolts and shackles.
  8. May 12, 2013 at 9:14 AM
    milorsm1
    Robby
    Louisiana
    01 SR5 4x4 TRD
    Thanks guys for the ideas. I have ordered all new bolts as for the front eye bolts grinned of the heads of bolts and used an air chisel to get them out. Pain in the butt! The new leaf packs will be worth it though.
  9. May 12, 2013 at 12:49 PM
    Snowman
    Snowman I have a problem for your solutionÂ…
    Craig
    Somewhere in Canada
    Check out my build
    I used a cut off wheel.
