rear leaf question???
Discussion in 'Street Trucks' started by slickrick614, Feb 6, 2014.
  1. Feb 6, 2014 at 6:51 PM
    slickrick614
    slickrick614 [OP] Well-Known Member
    Ricky
    wanaque nj
    06 taco 2wd 5spd
    Performance clutch, aero turbine 2525 muffler, 6k hids, 5% tints, smoked tail lights
    Can anyone tell me how much of a drop I will get by swapping the stock 5 lug rear leafs for 6 lug? I understand that the 5 lugs are under axle and the 6 lug are ovr axle, so whats the total drop ill get with that....and can I do that with the djm kit?:confused::confused:
  2. Feb 6, 2014 at 7:12 PM
    slickrick614
    Ricky
    wanaque nj
    06 taco 2wd 5spd
    And im all over the place with this drop kit.....basically I wont my tires to tuck a little.....how low do I have to go to achieve this???
  3. Feb 7, 2014 at 12:44 AM
    Brendo Ballz808
    Brendo Ballz808 Slammed or lifted.. ANYTHING IS BETTER THAN STOCK
    BRENDEN
    Oahu
    SNOFLAKE
    Check out my build:)
    What tire size you running just jdm alone won't make you tuck I'm running it's coils and I'm about to tuck up front with smaller that stock height tires and flush in the rear
    The 4x4 leafs seems to vary in drop dorm what I witnessed when I had em I was about 1.75" drop with the leaf others have 1" or 1.5"
  4. Feb 7, 2014 at 7:11 AM
    slickrick614
    Ricky
    wanaque nj
    06 taco 2wd 5spd
    For a while I'll be running stock 15 inch steelies with 235/75/15 tires
  5. Feb 7, 2014 at 7:15 AM
    slickrick614
    Ricky
    wanaque nj
    06 taco 2wd 5spd
    Oh and btw...I'm doing Djm 3/4 drop with 1 or 1and a half inch spindle spacers and then the notch and 6 lug leafs in the rear and will be getting the xr Billy's with xii performance stock height springs and QA1s for the rear
  6. Feb 7, 2014 at 3:15 PM
    Brendo Ballz808
    BRENDEN
    Oahu
    SNOFLAKE
    Aight right on you will be close with juat djm on those tire size but wont tuck when you add the spacer you will tuck and rub like a bitch however idk if the 15s clear the spindle nuts once the spacer is added im running 245/35/19
  7. Feb 12, 2014 at 7:26 AM
    Kelson
    Kelson My Truck is Cuter than Yours
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    x2. depends on the weight of the truck (access vs. reg)
    but it will be around 1.5" to 1.75"
    and these trucks, you need to go very low to tuck. and the frames hang quite low, so you'll be scrapin'
  8. Feb 12, 2014 at 4:07 PM
    slickrick614
    Ricky
    wanaque nj
    06 taco 2wd 5spd
    Thanks I got a reg cab....those tranny crossmembers do hang low lol until I can get bigger wheels im just gonna run the djm 3/4 kit and some qa1s on 235/75/15s and hopefully once this shitty new jrsey weathr goes away ill get some 18s or 19s then add the spacer and 6 lug leafs
  9. Feb 12, 2014 at 5:37 PM
    Brendo Ballz808
    BRENDEN
    Oahu
    SNOFLAKE
    Yup super shitty how low they hang compared to the 1st gens
    My crossmember is 1 3/4" ans I literally sit just flush
  10. Feb 13, 2014 at 11:15 PM
    07TacoRidah
    07TacoRidah SHHHH, this is interesting
    2007 Base Model Access Cab
    Engine bay: aFe Pro Dry filter Secondary air filter deleted Sokie Tech hood damper kit Xscorpion dual 0g wire ring terminal (3) Big 3 upgrade (0g wiring) HID kit (headlights, H1 - 8k) HID kit (fog light 3k) Sylvania Zevo LED turn signals w/hyper flash resistors Rear back up light GY6 bulb Bullz Audio 0g wire Exterior: Dynamik Retro Projector style headlight housing Depo Euro Black Altezza LED tails Front grille swap (to chrome, painted w/bedliner paint) XR front bumper valance (dipped red) Aftermarket fog light kit w/OEM switch Rear bumper swap (to chrome, painted w/bedliner paint) 99 Cents Store tailgate lock Suspension: DJM 3/4" drop kit 1" spindle spacer kit 4x4 leaf pack swap (middle leaf removed) Air Lift rear helper springs Rims: 18x10 Work VS-KF front w/5" lip 18x11 Work VS-KF rear w/6" lip 225/40/18 tires all around Neochrome lock nuts Pepboys valve stem caps Interior: Wink Mirror rear view Center console lid fabric Metra Dash kit Kenwood bluetooth headunit Hifonics Zeus ZXi 6410 PB 6 1/2" component speakers up front 10" JBL GTO 1014 (2) 4 ohm svc in dual ported box JDM Fuchsia shift knob (Crown Royal shift boot)
    true dat but to get a, imo, NICE low, your going to have to cut (cut off that bump stop hump and plate, along with low pro bump stops and notch the rear or your going to hit the frame). no ways around that. I'm running 225/50/18 in the back (equal to 235/35/20) and at full drop to my low pro bumps I still have wheel gap. Up front I have 225/40/18, still wheel gap BUT there's maybe just a lil more I can go (at most maybe an inch) before I have to cut off that bump stop hump to start considering tucking. Keep in mind that your wheel well is around 22" in diameter.
  11. Feb 14, 2014 at 5:24 PM
    slickrick614
    Ricky
    wanaque nj
    06 taco 2wd 5spd
    Oh yeah definitly I already ordered the djm kit that comes with the notch kit for the rear....so that will be 4 inches in the back and im getting 4x4 leafs which will be supposedly another inch to 1.5 and then spindle spacrs for the front....so ill be sitting at 4/5 drop maybe a little more then eventually get coilovers....but im hoping if I put a littke meat on my tires it will go up in he fender a little
  12. Feb 16, 2014 at 11:22 PM
    07TacoRidah
    Have a look in your driverside fender, there will be two tabs sticking out. Cut them off, you dont need them.
  13. Feb 16, 2014 at 11:38 PM
    Brendo Ballz808
    BRENDEN
    Oahu
    SNOFLAKE
    I smashed those fuckers in haha
  14. Feb 17, 2014 at 5:08 AM
    slickrick614
    Ricky
    wanaque nj
    06 taco 2wd 5spd
    Front or rear?
