Rear Leaf Recall
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Golf Man, Apr 6, 2016.
  1. Apr 6, 2016 at 8:28 AM
    Golf Man
    Golf Man [OP] Active Member
    Northern IL
    2023 Magnetic Gray TRD Sport
    I recently called to schedule the recall repair on my 2008 offroad. I asked what was Toyota's fix and was told they were going to add an additional clamp to the existing spring package. I asked how that was going to solve a fracture due to stress or corrosion as noted in the recall notice, explaining that 3 bags of groceries will take the bed to the bump stops with the stock spring. I had the tech look up the repair protocol and he repeated that this is Toyota's fix. Has anyone else ran into this or did I speak to someone who was simply uninformed? I was under the impression they were going to replace the spring with a 4 pack. Thanks in advance.
  2. Apr 6, 2016 at 9:12 AM
    bdevr
    bdevr Well-Known Member
    Brian
    Blue State He**
    '10 4 popper
    Most likely a misinformed employee. I was given bad information from my local service dept multiple times before the "remedy" became "active" in this area.
  3. Apr 6, 2016 at 3:27 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    My springs were completely replaced - no add a leaf. Someone is Zooming U. Hopefully someone on TW can tell you how to contact Toyota with a clue instead of the idiots U R dealing with
