Rear Leaf Replacement
Discussion in 'Suspension' started by ZeroRomeoBravo, Nov 4, 2020.
  1. Nov 4, 2020 at 12:48 PM
    ZeroRomeoBravo
    ZeroRomeoBravo [OP] New Member
    Zane
    2013 Black Tacoma 4x4
    I have a 2013 Tacoma 4WD with 265s, and I have a broken rear leaf. I'm trying to determine what my best option is in terms of replacements. I'm not necessarily trying to add lift, and if I did I'd want to keep it minimal. I'm seeing replacements that basically keep it stock from places like NAPA and Autozone, or leaf packs that add 2 inches of lift like the old man emu from ARB. I'd be looking to stiffen the load range if possible, because I have a topper and frequently tow a trailer... What options do I have beyond what I've listed?
    The other questions that I'm attempting to answer are as follows:
    What is the factory load rating for tacoma springs and are most aftermarket packs comparable?
    If I were to go with an option that had 1-2 inches of lift would I need to replace any other parts to be compatible?
    Thanks
  2. Nov 4, 2020 at 12:53 PM
    reg0928
    reg0928 Well-Known Member
    Ross
    Crestone, Colorado
    05 TRD OR Access Cab
    3"OME, 255/85R16
    There was a factory recall for leaf springs because they often broke. May want to look into whether or not your truck qualifies for the recall. Toyota will replace your leaf springs at the dealership if so
  3. Nov 4, 2020 at 12:59 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    I replaced the rear shackel(s), bolts and bushings along with the leaf springs. Not all necessary but I find it’s easier to replace rather than refurbish. How are your rear shocks since you will be in there anyway?
    Edit: It’s not recommended to reuse u bolts.
  4. Nov 4, 2020 at 3:08 PM
    757.Taco
    757.Taco Well-Known Member
    Nick
    Weatherford, Texas
    2009 4x4 Manual RC
    If they haven't been replaced already, Toyota will replace the stock 2nd gen leaf springs under a warranty. You can check this website https://www.toyota.com/recall to see if they've been replaced, just put in your vin or plate number. The replacement leaf packs generally add about 1" or 3/4" lift after they've settled since they have an extra leaf, plus they're free under warranty.
  5. Nov 8, 2020 at 9:06 AM
    chop
    chop Well-Known Member
    byron
    British Columbia
    08 Tacoma 4x4 dclb TRD Sport 4.0L
    3"lift , arb front bumper,ome 886 coils, icon xrt leafs goodyear duratraxs firestone air bags
    I just ordered icon xrt rear leafs. Sick of the shitty oem on a block. Just need to pick level 1,2 or 3
  6. Nov 8, 2020 at 9:11 AM
    MSN88longbed
    MSN88longbed Sporty Shorty
    Goleta, CA
    2014 Single Cab 4x4, Auto, Blinding White
    Kings all around, Method 306, Cooper STT Pro 265 75/R16, JBL amp, Morel Speakers, Undercover tonneau, Alcan leafs, SOS sliders, RCI skids, SSO Slimline, Engo winch.
    I installed leafs from Alcan and they are outstanding, just pricey.
    You give them your specs and tell them what you are looking for and they build them to do the job.
  7. Nov 8, 2020 at 11:48 AM
    clenkeit
    clenkeit Well-Known Member
    Colin
    Lakewood, CA
    2010 White DCLB TRD Sport
    If you can't get the new TSB springs for free from the dealer then the next cheapest option would be to find a near-new set of used 3rd gen leaf springs. You can often find them for dirt cheap. That'll get you back to stock. Then if you want a little extra lift you could buy an add-a-leaf.
  8. Nov 8, 2020 at 7:34 PM
    757.Taco
    Nick
    Weatherford, Texas
    2009 4x4 Manual RC
  9. Nov 10, 2020 at 11:01 PM
    ZeroRomeoBravo
    Zane
    Nope. My truck doesn't qualify for the recall replacement deal, so I need to go with a true replacement. I'm basically stuck between doing a full lift on the truck or just replacing the stock springs. Gotta figure out how I want to spend my money.
    757.Taco[QUOTED] likes this.
  10. Nov 11, 2020 at 5:37 AM
    chop
    byron
    British Columbia
    Look at icon xrt leaf system, you can adjust it as you like
  11. Nov 11, 2020 at 9:05 AM
    757.Taco
    Nick
    Weatherford, Texas
    2009 4x4 Manual RC
    Dang, that's a bummer. Best of luck!
  12. Nov 11, 2020 at 9:08 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    I recommend 1, from personal experiences, 2 sucks unless you have like 4-500 pounds of shit at all times
  13. Nov 11, 2020 at 9:13 AM
    LoveableWerewolf
    LoveableWerewolf Well-Known Member
    Nashville
    2014 5 lug, 1989 mighty max
    4 runner seats, storage cubbies
  14. Nov 11, 2020 at 9:43 AM
    chop
    byron
    British Columbia
    How much lift do you get with option 1? I have about 380lbs all the time. I'm looking for 2 1/2 to 3" with the weight
  15. Nov 11, 2020 at 9:47 AM
    coopcooper
    alberta canada
    around 3 inches but im stock weight
  16. Nov 11, 2020 at 9:56 AM
    chop
    byron
    British Columbia
    So I'm thinking opion 2 and maybe go to 3.
    I carry cap, rack, electric boat loader, boat and lots of gear as so tow a trailer on weekends
  17. Nov 11, 2020 at 11:21 AM
    ZeroRomeoBravo
    Zane
    Yeah I have a topper and I keep a whole bunch of gear and tools in the truck at all times and trailer frequently so I'm thinking 2 if I go with the Icon
  18. Nov 21, 2020 at 10:12 AM
    chop
    byron
    British Columbia
    Need new shocks, will 5100's work or 5125?. What are you guy using for icon xrt leafs
  19. Nov 22, 2020 at 6:15 PM
    lamjam
    lamjam Well-Known Member
    Los Angeles
    2021 TRD Off road 4x4
    how much did it ended costing you? I’m interested in a set too
  20. Nov 22, 2020 at 10:19 PM
    MSN88longbed
    Goleta, CA
    I will look at my records tomorrow and let you know.
    lamjam[QUOTED] likes this.
