rear leaf spring broken
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LASTCOWBOY, Jul 26, 2010.
  1. Jul 26, 2010 at 9:45 PM
    LASTCOWBOY
    LASTCOWBOY [OP] Member
    PUERTO RICO
    TACOMA TRD OFF ROAD SR5 2006
    My tacoma trd 2006 have rode 120,000 miles. During the past two weeks i was hearing a noise seems like a hard metal hitting under the cargo area. Today i took it to a mechanic and found that the rear leaf spring of the driver side was broken. I made a lot of calls and the leaf is sold in full sets (left side set and right side set), not individually. Each set cost between $500 to $600. I want to know if my truck qualifies in the tsb 0305-08, i brought it on december 2009 with 90,000 miles.
    Lastcowboy
  2. Jul 26, 2010 at 9:55 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    TSB's only apply within warranty. A few exceptions have been made, but that's rare and strictly the dealer's call.
  3. Jul 26, 2010 at 11:01 PM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    Your better off going with after market leafs springs
  4. Jul 27, 2010 at 2:31 AM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    You can buy a single leaf at an autoparts store and have in installed in the OEM pack. This is your cheapest option if that is the route you seek.
  5. Jul 27, 2010 at 6:08 AM
    raycie
    raycie Well-Known Member
    Oahu, HI
    2013 DCLB / 2016 4R Trail
    In need of $$$
    ^^^ or a spring shop can make you a replacement one.
    Just curious.. how do you drive you truck? Just wondering what type of conditions would have caused it to crack..
  6. Jul 27, 2010 at 8:23 AM
    scottri
    scottri Well-Known Member
    Scott
    Tigard Oregon
    '10 Sport DC TRD Sport PreRunner
    Cover King Seat Covers, WeatherTech Liners, PopNLock, storage bin locks, N-Fab Step bars, and G4 Elite Tonneau cover.
    I'd go after market or a spring shop. I had the springs on my 69 GMC rearched a few years back for like $90 and it made a huge difference and was much cheaper than buying new ones and they have held up great.
  7. Jul 27, 2010 at 11:06 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Keep in mind, one new leaf will cause. A partial lift where installed. It will be stronger on that side and not ride the same. Replace both sets and be done with it, or keep replacing them as you go.
  8. Jul 27, 2010 at 1:57 PM
    LASTCOWBOY
    PUERTO RICO
    I usually drive on asphalt roads, and the loads doesn't excede the weight stablished in the owner manual. I think that this leaf was cracked before I buy the Tacoma, and the crack was hiden because it was separated in the place where the leaf was atached to the truck's rear axe. But such is live, I took off both sets of leafs ( left and Right) and went to a Spring Repair Shop at Bayamon, PR, today, where it be install a pair of leafs in each set to convert the 3 leaf into 4 leafs. the job cost $290.50 for both sets
  9. Jan 17, 2011 at 8:54 AM
    gymsbyjo
    gymsbyjo New Member
    I have the same problem. 2005 Tacoma Double cab with 115,000 on it. The rear left leaf spring is broken. I was just searching for a leaf pack. Is this a common problem? i also only drive it on the road.
  10. Jan 17, 2011 at 9:13 AM
    ryanr623
    ryanr623 Well-Known Member
    Only if you bought the toyota certified platinum (not gold) warranty. I dont know what the max amount of miles it can have on to be certified, however.
  11. Jan 17, 2011 at 9:21 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Typically the leafs will sag if simply overloaded. The culprit is likely material defect (e.g. embrittlement during heat treat), pre-existing notch damage, corrosion or a combination of the three. Under the previous owner, has the truck always been in PR?
  12. Jan 17, 2011 at 9:22 AM
    shook0002
    shook0002 "The Fuzz"
    Joe
    Philly
    '08 Doublecab 4X4 SR5
    So many people on here take off their stock leafs that I would buy a used pair from somebody on here and save a lot of cash. Post up a want to buy in the classifieds. They're pretty easy to install so you can save money there by doing it yourself with a jack, friend and a ratchet set.
  13. Jul 12, 2011 at 4:30 AM
    caribou_frank
    caribou_frank New Member
    Tacoma SR5
    Within a year of purchasing my Tacoma I complained that the truck would bottom out with a very light load. They apparently checked it over and said there was nothing wrong. I never carry anything heavy in the truck and only drive on roads.
    Recently I returned from vacation and could hear a metal on metal noise coming from the rear. Upon inspection I noticed the center leaf on the right side was completly broken and hanging loose. The center leaf on the left side was also broken but still in position.
    I have had a few light truck in the past and hold on to them for at least 10 years. Never a broken spring.
    I returned to the dealer and was told that because I was over the 30k miles the repair was not covered even tho I complained well before the 30k period. They said I would have to take the complaint to Toyota, but in their experience as they had seen this many times before and said Toyota would not offer any compensation.
    I had OEM springs installed at the dealer at a total cost of $600. I thought they would have waived at least part of the cost/labour but no such luck.
    Good-bye Toyota.
  14. Jul 12, 2011 at 4:37 AM
    808hiker
    808hiker Taco addict
    Justin
    Big Island, Hawaii
    My dealer refused to do the TSB even with proof. Ehh, in retrospect I'm glad I went with new leaf packs instead of starting a big fight over it. Better quality with my Dakar's and it won't sag again like the AAL's tend to do.
  15. Jul 12, 2011 at 5:09 AM
    hillbillynwv
    hillbillynwv Well-Known Member
    Fairmont, WV
    2017 Tacoma 6MT TRD Pro
    Falken Wildpeak MT 285's
    The three leaf packs on my old 95 Tacoma broke on both sides. A local spring company made me new 4 leaf packs and they were fine and never had a problem.
  16. Jul 12, 2011 at 1:51 PM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Prices? What company? Pls.
  17. Jul 13, 2011 at 4:53 AM
    hillbillynwv
    Fairmont, WV
    Point Spring & Driveshaft Co.
    274 Van Kirk Dr
    Fairmont, WV 26554-9788
    (304) 534-3306
    It has been so long ago I forget the cost of the leaf packs. But, at the time
    I was living in Florida and it only cost $50 for them to ship them to me. Just
    call them and get a quote.
  18. Sep 9, 2012 at 11:56 AM
    wayne0000
    wayne0000 New Member
    Here is a link to Generalspringcompany. I bought a new right rear for $200.00
    generalspringkc.com
  19. Oct 22, 2012 at 3:26 PM
    pmo
    pmo Well-Known Member
    Nova Scotia Canada
    2007 Tacoma 4x4, DC, 6 Speed Manual.
    2007 dblcab bottoms out....going to re-build with two 2-1/4x5/16 lkeaves on each side....
  20. Oct 22, 2012 at 3:33 PM
    Slesse
    Slesse Tacoma level 27
    Kyle
    Port Coquitlam
    08 Tacoma
    Pro Comp Rims;32" Duratrack Tires; OME heavy duty lift in rear; 2" spacer lift in front; custom raised bed in box; Lear canopy; grillcraft grill; Rosen Head unit; Trail gear sliders; Tinted windows all around; Intermittent Wipers; White LED dash; Deactivated seat belt buzzer; Blue Sea Fuse panel; BAMF light bar running 4 Lightforce 170's (2 HID); FX-R retro HID's 4300k, with amber halo's, BHLM with black reflector bowl; stealth mode; Fenix Hide-a-way flashers as DTRL's; VIAIR OBA kit with 2.5 gal tank; 14" Magnaflow stainless steel cat back exhaust; de-badged; Hybrid badge applied; seasonal 4wheel camper "Fleet"
    I've got 50,000km on my 08 Taco, and i only pull the occasional toy (sand rail and boat) and i keep a canopy on it. I am the original owner and my springs were completely sagged out (not broken). IMO the stock springs are complete JUNK! and you are far better to go with an aftermarket set. it's more money but in the long run worth it. This ways it's an excuse to get a lift opens the doors for bigger tires, etc...
