Rear leaf spring squeakiness -- Dakars, Alcans or all?
Discussion in '1st Gen. Tacomas (1995-2004)' started by steve2267, May 1, 2019.
  1. May 1, 2019 at 7:39 AM
    steve2267
    steve2267 [OP] Small Mammal Fire Support Team
    Colorado
    04 Double Cab Tacoma 3.4L 4WD/TRD
    When I mentioned to the mechanic who is doing my frame replace my interest in a Full OME setup, he immediately brought up squeaks. Several people he knew that were running OME Dakars all had rear end squeaks. He suggested All-Pro Expeditions.
    After talking with Lincoln @ All-Pro yesterday, I've ruled out Expos because they are not going to handle my daily load of upwards of 900lbs.
    After searching and reading several 1st Gen squeaky threads, I've kind of come to the conclusion that most, if not all, Tacoma rear ends squeak. One poster said, "It's a Tacoma thing."
    My questions include:
    1. Do all aftermarket, lifted, rear leaf spring packs squeak, or end up squeaking at some part?
    2. Does anyone have OME Dakar's that do not or have never squeaked?
    3. Do Alcan custom packs squeak?
    4. This squeakiness that I read about... is it just little squeak-squeak-sqeak... or is it REALLY LOUD?
    Has anyone run both Dakars and Alcan customs? Did they both squeak? Or was one noticeably quieter than the other?
    2002Tacoma4x4 likes this.
  2. May 1, 2019 at 7:43 AM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    I run dakar heavies on my 2nd gen. It's a subjective thing but is is really pretty bad. In the cab is fine, but with the windows down or to a bystander, it is pretty horrendous.
    rosswood and MattCowsmasher like this.
  3. May 1, 2019 at 7:46 AM
    steve2267
    Colorado
    Am hearing from a fellow with Alcan customs that they squeak like a mofo if he doesn't liberally spray them with some sort of lube regularly. Sounding like it really is a "Taco thing."
  4. May 1, 2019 at 7:53 AM
    kwolf9202
    kwolf9202 Well-Known Member
    Kris
    Morrison, CO
    2018 TRDOR DCSB
    Just put OME's on this past weekend. No squeaks yet but I've only put 100 miles on them...
    Jimmyrace and MattCowsmasher like this.
  5. May 1, 2019 at 8:06 AM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    Didn't have any issues with the dakars until I installed the AALs. I am 100% convinced the squeaking I have is due to the lack of isolators/friction pads (whatever you want to call them) on the AALs.
    Had someone suggest to me (sorry, can't remember who it was) to try using this:
    https://pilotshq.com/dow-corning-molykote-321-anti-friction-coating-p-12905.html
    At least one person has had isolators added to the AALs
    https://www.tacomaworld.com/threads...-and-adventures.362772/page-130#post-13393533
    Going to try the molykote next but yeah, its a PITA. I love the OME ride but damn noisy. FWIW, some don't have any issues apparently. :notsure:
  6. May 1, 2019 at 8:08 AM
    Beretta4x4
    Beretta4x4 What makes the green grass grow? TTC#0114
    Josh
    Temple, TX
    6-speed death mobile
    My Dakars squeak over every bump. I've had them on for 28k miles so I just live with it.
  7. May 1, 2019 at 8:44 AM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    Call these people.
    www.nationalspringinc.com
    Good luck.
    MattCowsmasher likes this.
  8. May 1, 2019 at 8:48 AM
    4wdExplorer
    4wdExplorer Well-Known Member
    Orange County, CA
    My Dakars do not squeak at all and its been 8 months of daily driving and 2 off road trips.
    Here is the trick before installing the Dakars.
    1. Buy leaf liners and double sided tape. Take apart the leafs its easy. I did not even need a C clamp to remove the leafs or needed C clamps to put them back on. Install the double sided tape and place the leaf liners ontop of them. Repeat on each leaf.
    2. Go to Toyota buy 6 OEM bushings for the leafs. They are $8 each. Do not use the recommended poly bushings. Since there is no zerk fittings in the Dakar Leafs I did not want to use squeaky poly bushings.
    Look at my build thread of the part numbers.
    There you go. Quiet OEM leafs. Super happy I did the extra work since I want my truck OEM quiet just like a brand new truck.
    2002Tacoma4x4, gwiz, rosswood and 4 others like this.
  9. May 1, 2019 at 8:51 AM
    steve2267
    Colorado
    Appreciate your post. But am not finding your build thread... link?
  10. May 1, 2019 at 9:36 AM
    Gunshot-6A
    Conner
    Everett, WA
    Mine took about 9 months of sporadic offroad trips and a Utah winter. Give it time.
  11. May 1, 2019 at 9:53 AM
    Fluffymonkey
    Fluffymonkey Token
    College Station, TX
    2013 Trd Sport DC, 07 DC sr5, 03 Prerunner
    2003: Stock 2007: Avid Offroad sliders, 30% front tint, bed mat, Truxedo low-pro qt tonneu cover, aero turbine 2525 muffler w/ 8'' tip, AR25 Resonator, 16x8 Dick Cepek DC-1 w/ 265/75 Goodyear Wrangler Duratracs, 2010 headlights, ome 884 coils with .5'' top plate spacer, OME sport front shocks, bilsten 5100s rear, 2'' aal, locking gas cap, LR ucas, Viper 2-way remote start, afe drop in filter, Rocky locking bike mounts, gear chest, scangauge, pop n lock tailgate lock 2013: most things transferred over from my 07, 5100s @ .85 + eibachs and Toytec tps for 3'' front lift, wheelers progressive aal w/ overload; compustar 2-way remote start; Antennex shorty antenna, pop n lock tailgate lock with programmable key, seat covers, Toyota's crappy all-weather floor mats (should have got Husky's or Weathertechs), TRD skid plate, led light pods mounted in front bumper valence w/ Eyourlife wireless harness and remote, led bed lights, light pods mounted in bed, Devil Horns emblem from Diaz Fabrications, rear facing pod lights in bed, under seat lights,
    My observation, after being on this site for a number of years, is that all leaf springs will eventually squeak (stock, aals, dakars, deavers). This has been a recurring thread theme, and that tells me no one has yet found a permanent solution. My sqeaking tends to be due to the leaf pack shifting left or right and rubbing against the metal retaining clips. I've tried many of the 'solutions' i've come across on this site (rubber bicycle innertube, toolbox liner, liquid silicone, white lithium grease, etc) but the best solution i've found so far is just a lubricating oil. It penetrates well and sticks to the metal well, especially in those pesky friction spots. I get underneath and apply it once every couple of months and my springs are quiet as a church mouse.
  12. May 1, 2019 at 10:30 AM
    NYCTaco52
    NYCTaco52 Half man, half goat
    Somehow known as Stewart, but named Ben
    Ft Lauderdale, FL
    2022 Subaru Ascent
    Buy grade 8 bolts with zerk fittings. I grease them every oil change which is extremely simple and haven’t had any sounds from the leafs since I did that. I believe I got the bolts from wheelers (not sure)
    Edit: I also fluid film the entire underbody often, including the leaf packs, I’m sure it helps.
  13. May 1, 2019 at 10:31 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    My icons don't squeak :notsure:
    2002Tacoma4x4 and MattCowsmasher like this.
  14. May 1, 2019 at 10:38 AM
    MattCowsmasher
    MattCowsmasher ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Temple, Tx
    O3 Rubicon wrangler
    My hd dakars got the squeakers after 10 months an one good muddy wheeling trip. Now I spray it with fluid film an it’s good till next good pressure washing.
  15. May 1, 2019 at 11:47 AM
    NYCTaco52
    Ft Lauderdale, FL
    2022 Subaru Ascent
    Yeah man, fluid film is amazing. Love that stuff. It gets into everything so I never have to pry the leafs apart
  16. May 1, 2019 at 12:39 PM
    monoman
    monoman Time to get dirty!
    Dave
    Exotic, San Jose, Cal.
    2018 Silver Sky Tacoma SR Access Cab 4X4
    SnugTop SuperSport shell CaliRaisedLED light bar BFG K02 AT’s RCI skid Bilstein 5100's up front, (#2) & 4600 in rear N-2 Designs remote start/keyless entry Anytime 12v outlets... one by shifter & one in bed Daily driver....
    I have Alcans, had em for years. The only place they squeak from is the front eye. I put in rear greasable shackles when i did the install so no squeaks there. Next time I install rear springs I'll put in front greasable bolts. For now, when it starts squeaking, I just add a few drops of oil to the front eye bushings. Lasts for several months...
  17. May 1, 2019 at 12:42 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Those teflon pads they put between the leafs are wear parts. They wear out and need to be replaced periodically. How long they last depends on how you drive.
    Just about every wheeling trip I've been on there's at least one guy with squeeky leafs, it's not really a "tacoma thing". It's just a "haven't gotten around to lubing or replacing the anti-sqeak pads" thing.
  18. May 1, 2019 at 12:47 PM
    chiefO
    chiefO Well-Known Member
    Fresno, CA
    2005 Tacoma 4x4 Double Cab SB
    My dakars have around 30k on them and they don't squeak. However, I pulled out the pressed in front bushings and replaced them with polyerythane.
  19. May 1, 2019 at 12:53 PM
    adamdsgn
    adamdsgn Well-Known Member
    Adam
    2003 Tacoma Double-Cab - TRD/4x4
    Replaced my rear leafs with General HD springs recently. Have about 4,000 miles on them so far. No squeaking whatsoever.
  20. May 1, 2019 at 12:58 PM
    Hawk373
    Hawk373 Well-Known Member
    2012 TRD Sport DCLB
    DMZ, ADS, King, JFR, SOS, ECGS, LSK
    Had custom Alcans for about 60k with no issues. Great ride too. A friend advised me to order them after switching from Dakar to Alcan because of how rough a ride the Dakars had (no load in the bed).
    Now I run DMZ Deavers and the worst I get is lots of creaking during articulation which I see as normal.
    Deaver or Alcan will build you springs to your exact needs.
