Rear leaf springs and bed weight limit
Discussion in '3rd Gen. Tacomas (2016-2023)' started by corona56, Jul 18, 2022.
  1. Jul 18, 2022 at 5:05 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    Half ton trucks depending on options are roughly double the payload of the Tacoma. My work f-150 is ultra bare bones but has 4x4 and the FX4 package and payload is 2200
  2. Jul 18, 2022 at 5:14 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    It will haul things as good as the 2nd gen Tacoma. Not as good as a full size GMC, just like it can't outrun a Corvette.
  3. Jul 18, 2022 at 5:34 PM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    Anything over 400 lbs and they squat pretty good. If using to haul landscaping supplies, I would replace bump stops with sumosprings.
  4. Jul 19, 2022 at 6:08 AM
    corona56
    corona56 [OP] Well-Known Member
    Tom
    Boston, MA
    09 DbleCab LB 4x4
    Added fog light mod Added delay wiper mod Alloy rims with BF Goodrich tires
    and back to my original question. Will it be as good as a 2nd gen with the 4 leaf spring pack or the USA spec 3 leaf springs which are terrible? This was really my only question in this thread. Did Toyota learn from their mistake with the USA spec GEN 2 Tacoma's and put in the actual spec springs and NOT the once designed to make my grandmother feel comfortable? The 3 leaf pack was ridiculous on the GEN 2's.
  5. Jul 19, 2022 at 6:11 AM
    LFOD
    LFOD Well-Known Member
    2021 SR5 DCSB
    OP I had this exact problem when I owned an 05 and now have a 2021. I had a 2005 SR5 DCSB. The original leafs and shocks were terrible. Driving down the highway and hit a small bump or dip and the back end hit the bump stops and bottoms out. Put a bike rack on the back or a small load in the back and the suspension bottomed out. I had the TSB done with new leaf packs and the OR Bilsteins and it was fixed. My 2021 SR5 DCSB rides almost exactly the same as the 05 after the TSB.
    I think that's the answer you are looking for. Is it the same ride and payload as an F150 or Chevy 1500 NO, and you probably understand that from your question, but it's WAY better than the original leaf packs on the Gen 2.
  6. Jul 19, 2022 at 6:19 AM
    corona56
    Tom
    Boston, MA
    09 DbleCab LB 4x4
    Yes thanks. I love my truck and want the same truck feel when I drive it. I really appreciate it. I have offset rims too which is nice; but I can add spacers to my liking to get that look and feel. I also got the answer on the engine torque and it seems like the 3.5 isn't really producing less than my 4.0. and yes I know it is not 70k 1500 and I drive back and force to SC and do not want to pay gas for that big boy anyway. Taco is not great for fuel, but not terrible either.
  7. Jul 19, 2022 at 6:29 AM
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    If you haul more than ~650 lbs in the bed or have a trailer tongue weight >320 lbs on a regular basis you'll probably want to add support to the rear springs. From my understanding almost all of the fixes stiffen the ride (except perhaps a perfectly matched replacement leaf pack). Toyota provides the stock leaf pack for it's ride quality and to sell trucks.
    Buy a 3rd gen and spend a few bucks optimizing it for your use.
    corona56[QUOTED][OP] likes this.
