Rear leaf springs are squeaking...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 15DCSBTSS, Feb 19, 2016.
  1. Feb 19, 2016 at 6:43 PM
    15DCSBTSS
    15DCSBTSS [OP] Well-Known Member
    2015 Tacoma DCSB SR5 4x4 TSS
    Smittybilt Tri-Fold Tonneau, Pop N Lock Tailgate Handle, OME887/5100/LR UCA's/HS 3 LEAF (on order)
    I installed my lift about a month ago, what would cause this? For the record, I took out the overload leaf and put the AAL in. It's the HS-3 progressive from HeadStrong.
  2. Feb 19, 2016 at 6:44 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Unfortunately it is normal. I still get squeaks and I left the overload in with the ICON 1.5 Progressive AAL I put in. The stock leafs suck.
  3. Feb 19, 2016 at 6:46 PM
    PVT Pablo
    PVT Pablo
    Paul
    Puget Sound, WA
    2016 4Runner TRD Pro
    Did you check the battery?
    I'm just messing with you, its pretty common for squeaky leafs. Lift the back of the truck up by the frame, spray some white lithium grease in between the leafs, and lower it back down. It took a couple of times doing this over the span of a few months but now they are quiet as can be.
  4. Feb 19, 2016 at 6:49 PM
    15DCSBTSS
    Gotcha. I assume I can use the white lithium grease in a spray can. Thanks!
    Unchained 5150 likes this.
  5. Feb 19, 2016 at 6:51 PM
    PVT Pablo
    PVT Pablo
    Paul
    Puget Sound, WA
  6. Feb 19, 2016 at 8:03 PM
    supra90140
    supra90140 Well-Known Member
    telford pa
    08 dbl cab 4x4 lb trd sport speedway blue tow pkg
    weather tech floor liners
    There are rubber pieces that sit between the leafs that wear out
  7. Feb 19, 2016 at 8:43 PM
    RugglesTarlek
    RugglesTarlek Well-Known Member
    California
    basic basic basic 14 AC
    Double check that everything is tight, if you haven't already.
