Rear leaf springs query
Discussion in '3rd Gen. Tacomas (2016-2023)' started by reconrover, Dec 16, 2021.
  1. Dec 16, 2021 at 10:34 AM
    reconrover
    reconrover [OP] Over torquing is my thing..dumbass
    Pat
    Longmont CO
    2020 Taco Off Road
    Elka front suspension, All Pro rear, with airbags, Decked drawers, Southern Off Road bumper, DRT hangers, Carven Exhaust, Stinger head unit, custom made topper, Vijay swing away rear bumper, etc etc
    Howdy all, (2020 Tacoma TRD Offroad crew cab)
    Just got all of my parts together for the front lift (Elka + JBA), and I'm on a pretty tight budget to complete the rear. I've talked to several folks, and most say that Deaver is the high end that I should get for the leaf springs (but of course, it's pretty much outta my price range). So I looked at OME's which are much more reasonable, and I believe Icon's hitting somewhere in the middle. I won't do blocks, and it sounds like an add a leaf is only a temporary....and maybe not great solution. So...thoughts?
    [I will be putting on an aftermarket bumper, decked storage with about 300lbs of gear, a spare tire, and a little while later down the road, an RSI topper]..oh, and 33's.
  2. Dec 16, 2021 at 10:35 AM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    Save up until you can install what you need.
    eurowner and Mark77 like this.
  3. Dec 16, 2021 at 10:38 AM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    I agree with this. You're going to be running Elka shocks... No sense in cutting a corner now!
    I will say that we have been selling a lot of Icon RXT leaf packs lately, and folks seem to be really happy with them! For the money I think they are a very good kit. A custom set of progressive Deavers is going to perform very well as well of course.
    Cudgel[QUOTED] and tonered like this.
  4. Dec 16, 2021 at 10:39 AM
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    Stay away from the Ome/Dakar leafs and you'll be good.
  5. Dec 16, 2021 at 10:41 AM
    memario1214
    Colton
    Missoula, MT
    I forgot to hit on this! I have to agree. They will supple up a little bit since you'll have static load, but I had them on my 05 Tacoma and could not have been more disappointed. Noisy, stiff... I won't personally run them again on anything I own.
  6. Dec 16, 2021 at 10:48 AM
    dirt_seeker
    dirt_seeker Well-Known Member
    Utah
    2017 TRD OR
    I've been happy with the Icon real leaf springs. As you likely know one advantage of Icon is it comes with an extra leaf that you can add as needed to achieve increasing stiffness. I seriously considered the Deavers, but my build is going slow and Icon let me change the pack as I add weight. Sure you have to take the Icons apart which kind of sucks but its only wrench time not more dollars, you have all the hardware right from the start. Unless you are planning on being super heavy in the bed Icons will likely be enough.
    71tattooguy and tonered like this.
  7. Dec 16, 2021 at 10:51 AM
    anthemAnathema
    anthemAnathema Well-Known Member
    2013 4.0 6MT Access Cab TRD Offroad
    Elka 2.5 w/ DSC RCI Skids AP Expedition Leafs Leer 180
    I've got Elka 2.5 DSC. Started off with a progressive add-a-leaf in the rear. The ride was pretty shitty. Swapped up to the All Pro expedition packs and couldn't be happier. I only have a fiberglass topper on the bed and ended up with a bit more lift than I wanted (2.75" after a several months of settling). The ride is incredible with these springs and they're cheaper than Icons.
  8. Dec 16, 2021 at 10:54 AM
    memario1214
    Colton
    Missoula, MT
    One thing I tend to catch people off guard with when they inquire about suspensions... AALs (generally) ride like shit. You think "oh I'm not putting in a block so it's an upgrade", and it turns out the ride is terrible! :rofl:
    Glad you found something you like though! :thumbsup:
    tonered likes this.
  9. Dec 16, 2021 at 11:08 AM
    Benny blanco
    Benny blanco Mr. Jiggletits
    Ben Day Ho
    Whoville<>Trollhättan
    21 Cement TRD OR MT
    Some stuff
    I picked up Toytec progressive aal pack. made by deavers. 1.5-2” lift.
    Ride is nice. squeaky though.
  10. Dec 16, 2021 at 11:10 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Buy once, cry once...
  11. Dec 16, 2021 at 11:11 AM
    OmahTako
    OmahTako Well-Known Member
    SoCal
    Tacoma-1ea. Tundra-1ea.
  12. Dec 16, 2021 at 11:20 AM
    memario1214
    Colton
    Missoula, MT
    Have you tried the bike tire trick? Cheap and effective. Go to walmart (or wherever) and pick up some bicycle inner tube. Cut it into like 5" strips and put it in between the leaf springs. Relax the rear axle, and use something to pry apart the leafs. Keep yer digits out of there! Clean them up with a brush or something similar, and then slide the bike tire section in right where the contact pads are. Did that on my OME pack and it worked like a charm for like 6 years without a single noise.
    whatstcp and tonered like this.
  13. Dec 16, 2021 at 11:25 AM
    OmahTako
    SoCal
    Or hose them off and spray silicon spray on them
  14. Dec 16, 2021 at 11:25 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Great tip!
  15. Dec 16, 2021 at 11:30 AM
    memario1214
    Colton
    Missoula, MT
    That likely won't work forever though. That stuff will wash out after no more than a few months... I don't think there's a lubricant that I DIDN'T spray into my OMEs trying to get it to stop. CRC White Lithium Grease was the best that I found though at like 6 months before they started to get vocal again.
    I'm not saying that what I proposed is the silver bullet, but if someone is battling with it I at least know it worked for me long-term.
    whatstcp and OmahTako[QUOTED] like this.
  16. Dec 16, 2021 at 11:33 AM
    OmahTako
    SoCal
    No it doesn’t work forever but for me it’s better than breaking apart my leaf pack. Doesn’t happen very often it just depends upon what I am driving through. Soft desert sand seems to have some affect on my Deavers.
  17. Dec 16, 2021 at 12:22 PM
    Mister Grey
    Mister Grey The Viking of disapproval looks in your direction
    Hayward Ca
    2017 Tacoma DCLB Sport 4x4
    The Works.
    I run OME's for 3 years now, no problems and I like the handling. There's no shame in running blocks till you can upgrade albeit there's no fun in it either.
  18. Dec 16, 2021 at 1:44 PM
    758_Moto
    758_Moto Well-Known Member
    2004 LT Taco, 2019 Taco
    2019: Icon Coilovers/UCA/AAL, 16x8 Methods/285 Duratracs, URD Spec-U Exhaust, Nexus +P Tune 2004: Chaos LT w/Kings/62" Deavers/12" TC Shackles, Glassworks hood/fenders/bedsides, TRD SC, URD fuel mods/lightweight flywheel/10psi Pulley, JBA Headers, TT Supra MAF
    I just installed an Icon AAL along with my coilovers and UCAs. With no weight in the bed the ride is definitely not great, over small bumps it's much stiffer than stock and very springy. With my dirt bike in the bed it rides much better than stock though. To the OP, if you're going to have constant weight in the bed, the AAL's would be a cheap short term option and work good enough until you could upgrade to full leaf springs. You could also leave the factory overload leaf in with the AAL if you're going to have enough weight to warrant it.
  19. Dec 16, 2021 at 1:51 PM
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    Fiberglass shell, sliders, and about 100lb of gear here, very happy with my dakar mediums, the new design doesnt squeek at all. You’ll probably want heavies if you’re going decked, 300lb of gear, and a bumper with tire carrier.
    how long till you can afford to buy all that stuff though? May want to buy the heavies, remove a leaf (making them mediums, and install it later once you have all that weight. That sounds like a heavy rear end though gotta say…decked+Rsi+Bumper and tire…might wanna rethink all that weight
  20. Dec 16, 2021 at 1:51 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Just a note as I have said it before, my stock leafs were jittery when empty. With the Icons on Option 1, it rides about the same, but without the jitter when empty. Very much surprised me.
    Much less body roll also.
    71tattooguy likes this.
