Rear leaf springs replaced by dealer for howl
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Lforgue8, Feb 21, 2019.
  1. Feb 21, 2019 at 6:27 AM
    Lforgue8
    Lforgue8 [OP] New Member
    2017 Tacoma Trd OR
    im new here because I just bought my new to me 17 OR 32k miles. Love the truck but had a howl right at 50 mph. Brought to dealer and they changed both leafs. Noise still there, but I did notice none of the hardware was changed. None. Not even the nuts for the U bolts. Is this not odd? Does Toyota not recommend replacing lock nuts or hardware with suspension repairs?
    Thanks guys this site has been great so far in my taco owner ship!
  2. Feb 21, 2019 at 6:28 AM
    tcjacado
    tcjacado Well-Known Member
    Welcome to TW
    Nunya Bizness likes this.
  3. Feb 21, 2019 at 7:04 AM
    Lforgue8
    2017 Tacoma Trd OR
    Thanks!
    tcjacado and Nunya Bizness like this.
  4. Feb 21, 2019 at 7:11 AM
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    Fixing the howl requires more than just the leafs per the TSB, they also need to change out the cab mounts if I recall as was stated in the TSB. I had this same issue and had it addressed last summer with the TSB. My U-bolts and hardware seemed to be the same as well and I don't think the TSB called for replacing of said hardware, just the leafs and something to do with the mount.
    It worked for mine - at least 90% of it. There is a small window where I can still occasionally hear a faint howl but if I hadn't had the louder howl I wouldn't even think a thing about it it's so faint..
  5. Feb 21, 2019 at 7:11 AM
    Scott17818
    Scott17818 Well-Known Member
    Scott
    Midcoast Maine
    2016 Tacoma DCSB OR
    methodMR305NV, 265/70/17duratracs, ARB RTT, DITCH Lights
    I had my dealer do the TSB for howling from the front lower control arms. they put plastic plugs in a few of the 5 holes in the lower control arms.. it still howls (not as bad as before) at around 52-55mph.. but other than that it's not bad at all..
  6. Feb 21, 2019 at 7:12 AM
    bshammer0
    Brandon
    Nashville, TN
    This! lots of debate on this one, but I have my u-bolts torqued to about 70. tighter definitely softens rear end hits and bouncing on the rear suspension. when I raised this to my dealer at the time the response I got was "looser u-bolts should help for a smoother ride" = bullshit. tighten those babies up if they are loose which seems likely based on what I've seen on here
    tcjacado and whatstcp[QUOTED] like this.
  7. Feb 21, 2019 at 8:29 AM
    Lforgue8
    2017 Tacoma Trd OR
    Looser u bolts??!! That doesn’t sound right. Leafs locate the rear axle why would you want that at 37ft/lbs! I’ve been in the dealer game for 18 years but not Toyota so I’m not 100% sure how they go about warranty work. I dropped it off today for the trans surge/ judder and a leak from either the t-case and or the trans.
