Rear leaf springs/ shocks question on 2015
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JBockman40, Apr 15, 2015.
  1. Apr 15, 2015 at 3:40 PM
    JBockman40
    JBockman40 [OP] Well-Known Member
    Hermitage TN
    2016 Double Cab 4X4 TRD OR 6MT
    I have a 2015 TRD 4x4 OR- just wondering what the best adjustment is to be able to hold additional weight in truck bed without excessive sagging and hitting bump stops- I normally at the most haul up to 500 lbs in bed and would like to know the best option without voiding my warranty or creating other problems.
  2. Apr 15, 2015 at 3:42 PM
    js6111
    js6111 MANXIT
    San Diego, CA
    10 Tacoma Access Cab TRD OR
    Readylift 2.25" spacer, Bilstein Strut, Weathertech Floormats, DEEZEE Bed Mat,Tekonsha Prodigy
    A progressive add a leaf such as Icon on wheelers will help a little bit ($170-220) , Dakar full leaf pack ($500), or air bags
  3. Apr 15, 2015 at 3:49 PM
    planetbuster
    planetbuster Well-Known Member
    San Diego
    2014 DCSB TRD OR Lifted+supercharged
    Someone school me, is this really needed for such a low amount of weight?
  4. Apr 15, 2015 at 4:04 PM
    js6111
    js6111 MANXIT
    San Diego, CA
    I have a 10 OR with the junky 3 leaf stock springs and I can easily carry 500+ with 2 dirt bikes and gear and it rides fine. A little nicer after I got 5100 rear shocks
  5. Apr 15, 2015 at 4:16 PM
    bucktales
    bucktales *Retired* curmudgeon
    Litchfield County Ct.
    2012 TRD Sport AC / 2014 FJC/ 1972 Rally Nova
  6. Apr 15, 2015 at 4:51 PM
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
    The simplest and cheapest way is to add a helper. I used the 2000lb hellwig EZ-990 for the TRD 4x4. They come with everything you need and can be installed in around an hour both sides with standard tools.
  7. Apr 15, 2015 at 6:20 PM
    JBockman40
    Hermitage TN
    thanks for all the info
  8. Jun 2, 2015 at 12:07 PM
    _gray_knight_
    _gray_knight_ Well-Known Member
    SoCal
    '18 Mall Crawler
    Just washed
    Any concerns of spacing on the driver side near the gas tank and brake line? Happen to have any pics? Read somewhere some bending of things and what not are required. Im considering the same solution as im on the non-TSB 3pac.
  9. Jun 2, 2015 at 12:13 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    I got the Wheeler's 3 Leaf Progressive AAL shipped to my door for $156, and it carries 500 lbs easy on my stock 3 leaf pack (2+1 overload). Rides well unloaded, which is the best part.
