Rear leaf springs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Flo_TRD07, Apr 23, 2022.
  1. Apr 23, 2022 at 10:39 PM
    Flo_TRD07
    Flo_TRD07 [OP] Well-Known Member
    Ben
    2007 Tacoma TRD Sport Prerunner
    Truck things
    Hey guys! So I'm starting to look into replacing my rear leaf springs... They're starting to be a little bit more frowny than smiley and I'm noticing a tiny bit of sag that never used to be there. I've been trying to research some new leaf springs but it seems like everyone upgrades their leaf springs for towing/hauling to accommodate their lift, which is not my case. I never haul more than 100lbs of stuff in my bed and want to ditch my 2-inch blocks (while keeping the same amount of lift) in the process of just getting new, refreshed leafs. Does anybody have any suggestions?
    I did get recommended to a local shop in Sacramento that builds custom leaf packs but apparently, it's somewhat pricey.
  2. Apr 24, 2022 at 4:17 AM
    Alealexi
    Alealexi Well-Known Member
    Houston, TX
    2007 Tacoma Prerunner
    Have you gotten the recall leaf springs? It could get you a new set for free if you haven't done it yet.
    OkieCowboy and Rocketball like this.
  3. Apr 24, 2022 at 5:08 AM
    AgentCovert
    AgentCovert Well-Known Member
    22 SR5 DCSB 2.7L
    Leaf spring helpers may work..about $30 at the part store if your not into towing and on a budget..might just be enough for your purposes..
  4. Apr 24, 2022 at 7:26 AM
    Flo_TRD07
    Ben
    Truck things
    I don’t think so…? My trucks an 07 that I got in 2020 so not sure if I’d still be able to do that or not
  5. Apr 24, 2022 at 7:27 AM
    Flo_TRD07
    Ben
    Truck things
    I’ve looked into those and I think I just want to replace the entire packs… I’ve replaced the whole front so I’m ready to do the back now as well
  6. Apr 24, 2022 at 7:33 AM
    tommytaco67
    tommytaco67 Well-Known Member
    vail
    2012 SR5 V6
    I just got my ironman 4x4 leaf packs, getting installed weds. 640 bucks delivered and includes u bolts.
    Flo_TRD07[OP] likes this.
  7. Apr 24, 2022 at 7:44 AM
    Rocketball
    Rocketball If The World Didn't Suck, We'd All Fall Off
    Scott
    Westminster, MD
    08 Speedway Blue DC Sport 4x4
    Pioneer head unit, PAC steering wheel control modual, Hard wired Sirius radio, Hard wired radar detector, Hella Supertone horns, Blacked out badges, Smoked Tails, BHLM (color matched Speedway Blue), T-Rex Eyelids, Black Powder Coated Billet Grill, Color Matched Engine Cover, Lund in channel vent visors, FJ Cruiser wheels, Leer 100XQ shell, OEM bed mat, Piezo beeper for locking doors, Tinted front side windows, Black Westin bull bar, Aires tube steps, Mini Maglite Mod, D-Cell Maglite Mod, Weathertech Digifit Floor Mats
    It was a factory recall. They were having issues with some individual leaf springs breaking if I recall correctly. Have your local dealship check their records and see if your vehicle got the leaf spring recall work done before you bought it. Regardless of who the current owner is they will know if it's been done. If not, you should be able to get a brand new set of rear leaf springs at no cost to you. I have an 08 Sport 4x4, and mine were done just a couple of years ago.
    Flo_TRD07[QUOTED][OP] likes this.
  8. Apr 24, 2022 at 7:45 AM
    killerkeener
    killerkeener Well-Known Member
    2011 trd 4x4 manual
    None yet
    Ome
    Deaver
    Dobinsons
  9. Apr 24, 2022 at 9:16 AM
    Alealexi
    Houston, TX
    The recall is still going so just taking it to a local dealer to check if it was still done won't hurt. I got my 07 used and was able to get my leaf springs replaced last year for free.
  10. Apr 24, 2022 at 9:19 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    Rear blocks are the worst route to lift a truck and will accelerate leaf spring wear and promote axle wrap. There are many options depending on your budget. Cheapest would be a progressive 3 leaf aal to a more pricier full leaf pack replacement that comes in different load applications. If you do end up with fresh springs with the recall and still need a small lift, I would look into a progressive 3-leaf aal for a softer ride vs a single aal.
  11. Apr 24, 2022 at 5:37 PM
    Flo_TRD07
    Ben
    Truck things
    Let me know how you like them!!
  12. Apr 24, 2022 at 5:38 PM
    Flo_TRD07
    Ben
    Truck things
    Thanks for the tip I’ll look into that as well!
  13. Apr 24, 2022 at 5:44 PM
    Flo_TRD07
    Ben
    Truck things
    Yeah I bought blocks as it was really all I could afford at the time but I’m little wiser with a little more jingle in my pocket now haha. I’ll look into the recall… If I can’t get the recall would you recommend getting a stock leaf pack and AAL or getting an aftermarket pack with the lift I want? Just going for the same 2 in. lift to level it all out.
  14. Apr 25, 2022 at 3:22 AM
    Wattapunk
    Uncle K
    TX
    2005 DCLB 4WD
    I would go with a full aftermarket leaf pack replacement. I run the medium duty ironman4x4 leaf packs for many years now with no issues. Ride quality is good with no squeaks along with approximately 2" of lift. I will replace with the same ones when mine wears out.
  15. Apr 25, 2022 at 4:41 AM
    pearing
    pearing Well-Known Member
    Wisconsin
    2015 SR5 quadcab
    Alcan. Check their website, they are really helpful and will make sure you get what you need. You will need to get under the truck and do some measurements.
    Alcan Spring Inc.
  16. Apr 25, 2022 at 2:15 PM
    agmason
    agmason Well-Known Member
    Austin, Texas
    2007 Prerunner 4dr LWB
    If the truck has not had the leafs replaced under recall, the dealer may try to get out of it if your suspension is not stock. I know the local dealer grilled me hard when I had the recall done about any suspension modification, seemingly with the intention of getting out of the recall.
  17. Apr 25, 2022 at 6:58 PM
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    Icon RXT. On option 1 you’ll get about 2” of lift and can ditch the blocks. Also nice to have flexibility for the other options if you ever add a cap or anything else heavy on a permanent basis.
  18. Apr 28, 2022 at 3:07 PM
    tommytaco67
    vail
    2012 SR5 V6
    Got my med duty ironman leafs installed and it has a great ride now, apprently I had a broken leaf per side. Got a nice lift and eliminated the squatting. I have a topper and sleep platform and maybe 100 lbs of gear at least at all times
    T
  19. Apr 28, 2022 at 7:33 PM
    Alexfiggy
    Alexfiggy Well-Known Member
    Alex
    Miami
    Trd off road
    I went to a local heavy duty truck spring shop and they ordered me some leaf packs from Dayton springs and they made the unbolts for it. The leaf packs where heavy duty compared to my factory ones 3 leaf’s and a helper . I spent about 459 on all of it and installed them myself. Also upgraded shocks to 5100 . Im happy with it so far .
  20. Apr 28, 2022 at 8:07 PM
    saint277
    saint277 Vigilo Confido
    The icon rxt leaf pack is good and adjustable for your weight.
