Rear leaf squeak
Discussion in '2nd Gen. Tacomas (2005-2015)' started by outlawtacoma, Jul 31, 2010.
  1. Jul 31, 2010 at 6:58 PM
    outlawtacoma
    outlawtacoma [OP] Well-Known Member
    W. TN
    2018 T4R MGM TRDOR Premium Daddy Wagon
    As many of you, I had acquired the nasty rear leaf squeak. I fixed mine the other night when installing my rear 5100s, and wanted to let you all know how. I put some grease around the bracket (?) that holds the leafs together and then beat the pee out of the bracket because it looked like it had shifted out, or opened up and wasnt holding it as tight as it should be. After this hardcore beating from my mallet all is well and not a sound out of it since. I could make the leaf squeak by just moving them a little force with my finger. Now they are quiet as a mouse.
    :D
  2. Aug 1, 2010 at 7:11 PM
    DevL
    DevL Well-Known Member
    Let us know how long it lasts... all 4 of my clamps squeek... white spray grease lasts 3-4 days and liquid wrech lasts about 5-7. If beating them tight is a cure I will do it.
  3. Aug 1, 2010 at 8:15 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    The best solution is new silencer pads. Leaf spring shop did my Tahoe for $50. Best money I ever spent.
  4. Aug 2, 2010 at 12:15 PM
    DevL
    But its not the leafs that squeak against each other its the clamps... do the pads stop the clamp squeek?
  5. Aug 2, 2010 at 12:51 PM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    A little spray of multy-purpose lubricant between the leaves took care of my squeaks. I did it a few months ago and it hasn't squeaked thus far.
  6. Aug 2, 2010 at 12:54 PM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    i got a feeling that tighting those clamps make it so the leafs cant move so therefore wont squeak. ive heard that the best solution is to take apart the leafs and put a bicycle innertube inbetween each leaf
  7. Aug 2, 2010 at 1:05 PM
    NAYo2002
    NAYo2002 Well-Known Member
    Great Falls, MT
    '09 Tacoma 4x4 TRD Off Road
    Michelin LTX A/T2, TRD Skid Plate, WeatherTech DigiFit Liners, OEM Bed Extender, OEM Bed mat, Advantage TorzaTop Trifold Tonneau, Pop & Lock PL5300
    If you are still under warrenty, there's a TSB for it. They just replace the friction/silencer pads but it's pretty good. The squeak came back after a few days in the mud but went back away with a car wash.
  8. Aug 2, 2010 at 5:22 PM
    outlawtacoma
    W. TN
    I did this too, but it was still squeaking until I lubed them up with some Mobile 1 grease and commenced to beat the snot out of the clamps.
    not under warranty..... 42k
  9. Aug 2, 2010 at 8:18 PM
    dexterdog
    Oly WA
    2012 F150
    The leaves need to move so the suspension can articulate. The metal to metal contact between the leaves causes a majority of the squeaks hence the silencer pad tsb.
