Rear leaf squeek help!
Discussion in 'Suspension' started by Misterclean, Oct 1, 2012.
  1. Oct 1, 2012 at 5:44 PM
    Misterclean
    Misterclean [OP] Member
    Salt Lake City, Utah
    2004 Double Cab 4x4 TRD
    Transmission Cooler, 2" lift front/w Billy 5100 Coilovers, 2" Pro-Comp AAL Rear/w Billy 5125's, Epoxy frame coating, Thule Basket W/Outdoorsman 300 bed rail towers, Black wheel coat
    Just recently, the rear leafs on each side at the front shackle have started to squeek... and it's driving me NUTS! Anyone have an easy lube suggestion or should I just take out bolt, drop leaf and put on Dry lube?
    FYI: (stock leaf pack W/Procomp AAL)
  2. Oct 1, 2012 at 11:52 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    No Truck..well, maybe
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Get the weight off the springs , pry the leaf ends & drop some squeak pads in
  3. Oct 2, 2012 at 7:22 AM
    Misterclean
    Thanks 4WD... but the squeak is coming from the shackle mount, not the leafs themselves. Any other suggestions?
  4. Oct 2, 2012 at 7:27 AM
    Yota4Ever
    Yota4Ever Well-Known Member
    Taylor
    Oregon
    Sas'd 00 4wd PreRunner
    38" Tsl Super Swampers 3-link front Fox 2.0 Built D44 Built D60 Cobra Cb
    Mine do it too I just spray WD40 in there and then push my truck up and down until the squeak fads away
  5. Oct 2, 2012 at 7:29 AM
    Tacoma9396jrc
    Tacoma9396jrc Well-Known Member
    Jacob
    South Carolina
    96 4x4 tacoma 4 cyl
    Cherry Bomb exhaust, 3" suspension lift
    Poor oil over the shackle and jump up and down on the bed. Thats what i did
  6. Oct 2, 2012 at 7:32 AM
    BulletToothTony
    BulletToothTony Space for rent
    You can call me Susan if it makes you happy.
    I used some white grease and no squeaking for over 6 months
  7. Oct 2, 2012 at 7:43 AM
    Misterclean
    I guess you guys have stated the obvious! I appreciate that and was about to do the same... I was thinking a longer-term solution with a dry-lube that wouldn't attract a lot of "Gunk". But that would mean unmounting the leaf pack from the shackle and I was hoping any summer projects were coming to a close!! WD40 might just be the way to go.....
  8. Oct 2, 2012 at 12:38 PM
    Misterclean
    Found out it wasn't the Hanger bolt on the shackle afterall... It was at the first spring clip on the leaf-pack!! Sprayed some dry-lube around the clip and between the leaves right at that point an VOILA, no more squeak!!
    Thanks anyway guys!
