Rear Leaf TSB completed today.
Discussion in 'Suspension' started by SmilingMark, Mar 18, 2011.
  1. Mar 18, 2011 at 11:29 AM
    SmilingMark
    SmilingMark [OP] Well-Known Member
    Mark
    Ogden, UT
    2010 Access Cab
    Color matched grill w/ grillcraft. BHLM and Morimoto Mini HID's Debadged.
    Had the rear leaf TSB done today (T-SB-0359-10). All I can say is "awesome". I can't believe I was satisfied with my ride in general before. As soon as I hit the first speedbump in the dealer lot I knew I was pleased.
    Suspension still all stock on stock tires and just a huge ride difference. Suspect I may have been slightly out of alignment before as the truck tracks better overall now as well.
    Sitting about 2" higher in the rear end now, but after reading many posts, I suspect that will settle quite a bit.
    Next step: 5100's all around!
  2. Mar 18, 2011 at 11:42 AM
    ds46000
    ds46000 Well-Known Member
    07 PreRunner TRD Sport
    glad you like it. should have put the 5100's on first and saved yourself the cost of an alignment. nice looking truck!
  3. Mar 18, 2011 at 3:54 PM
    elwood
    elwood "Really, how hard can it be?" Jeremy Clarkson
    Neal
    ont, canada
    2007 SR5 4x4 LB
    K/N cold air intake, leer cap, running boards, nose gaurd,E brake control, mud flap cut, suspension tsb, Rear diff breather mod,Factory Fog lights, Factory front diff cover
    Glad it worked out for you:). Mine didn't settle much at all and i have had my cap on the whole time. On a side note how do you like the BF rugged trail tires? Smooth on the highway? Quiet?
    cheers
  4. Mar 18, 2011 at 4:45 PM
    SmilingMark
    Mark
    Ogden, UT
    2010 Access Cab
    Yeah, they're fine, I guess, came stock from the factory. Not the best on snow, but the traction systems on the truck are so good they compensate for them well. Pretty soft, so I'm not expecting long life out of them. Once they wear down some I'll put on 5100's and the BFG AT's.
