Rear leaf TSB. Should I or should I not get it?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KevinD, Feb 3, 2011.
Is the rear leaf TSB worth getting done?
Poll closed Mar 5, 2011.
  1. Yes Im happy with mine
    56 vote(s)
    62.9%
  2. Yes but I haven't got mine done yet
    7 vote(s)
    7.9%
  3. No rides to rough
    1 vote(s)
    1.1%
  4. No sure don't have it done
    25 vote(s)
    28.1%
  1. Feb 3, 2011 at 5:55 AM
    KevinD
    KevinD [OP] I don't say to much
    Kevin
    NC
    09 PreRunner X-SP silverstreak
    Billit grill and window tent, HIDs, fog light mod
    I am just about past the warrenty mark on my truck for the TSB. I have been reading through some other treads about it and alot of you guys seem to have been really happy with your truck after it was done, but I have read a few that say the truck started riding alot rougher than they thought it would. I have an '09 prerunner. I do haul stuff like motorcycles, utility trailer, yard equimpent. I have noticed my truck sitting very low with not much weight in it and whiling pulling a trailer it seems extremly bouncy.
    What do you guys think. Is it worth it? And if I get it on my SR5 prerunner what all will they change?
  2. Feb 3, 2011 at 6:00 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    If you don't need it, don't get it. If you can haul what you need to haul and the truck isn't bottoming out and you've been happy so far, why change it? To give you a comparison, mine would bottom out hard with a motorcycle (about 400 lbs) in the bed on a moderately bumpy road so I got the TSB. If they do perform the TSB, it should be covered under warranty and wouldn't cost you anything. It does ride a lot stiffer. I like it but it's a personal preference. I also have a shell and have a decent amount of weight in the back at any given time so the TSB was a must for me.
  3. Feb 3, 2011 at 6:01 AM
    Burns
    Burns Excellent Member
    17 DCSB Off-Road
    Bilstein 5100's @ 2.0", Wheelers 1.5" AAL, 265/75/16's
    Yes do it, especially if you haul stuff. I am very happy I got mine done, the truck now rides the way it should of from the factory. :thumbsup:
  4. Feb 3, 2011 at 6:32 AM
    cc350
    cc350 Retired Member
    Better fix that typo "I have been reading through some other treads about it and alot of you gays seem to have been really happy with your truck after it was done"
  5. Feb 3, 2011 at 6:39 AM
    KevinD
    Kevin
    NC
    Ha good catch. I must change that!
  6. Feb 3, 2011 at 7:02 AM
    AzogSS
    AzogSS Well-Known Member
    Andy
    Soda City, SC
    2008 Tacoma / 2011 FJC
    No, if you have to ask yourself if you need it or not you shouldn't get it. I needed mine because I haul things.
  7. Feb 3, 2011 at 8:09 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    If , as you say OP , you haul in your truck , then yes.
    If you are the type of person that takes their truck in to have a 4th leaf added , knowing ahead of time that the ride will stiffen some , and then starts threads complaining that the spring TSB made the truck ride like a dump truck , then no.
    I can't take anymore . :)
  8. Feb 3, 2011 at 8:16 AM
    808matt
    808matt Well-Known Member
    hawaii
    19 Ranger
    if you need it get it, if not then dont. only you will know if you need it or not
  9. Feb 3, 2011 at 8:36 AM
    Fed Taco
    Fed Taco Well-Known Member
    Cale
    2011 TRD Off Road
    Wheels & Tires, weathertech floor liners, Areo Turbine Exhaust
    You should get it because they are suppossed to give you new shocks, then you don't have to buy replacements.
  10. Feb 3, 2011 at 8:39 AM
    ::childstoy::
    ::childstoy:: Hi-Tech Rednek
    Southeast, PA
    Black 2010 TRD Sport
    TRD Exhaust, Tint, Stubby Ant., Debadged, Weathertech Mats, Grillcraft... Currently collecting donations for a New Tires Fund.
    To be honest I hardly noticed the difference... The service guy was warning me about the ride, but after all it is a truck.
    I loaded it up with wood the other day and was very pleased that I got it done. :D
  11. Feb 3, 2011 at 8:41 AM
    Pugga
    Massachusetts
    Now there's a great reason to get the TSB done... :rolleyes:
  12. Feb 3, 2011 at 8:47 AM
    jivewalker
    jivewalker Well-Known Member
    Jack MeHoff
    Chucktown
    2012 4RUNNER TE w/KDSS, 2017 LAND CRUISER
    I had it done and am happy with the results. Much stronger.
  13. Feb 3, 2011 at 8:47 AM
    Devildoc
    Devildoc Well-Known Member
    Lincoln, California
    Speedway Blue off road
    Running board, K&N air filter, Nitto Terra Grapplers G2 on ProComp 7089(285/70/17), 3" front lift and 1.5" AAl rear, all with bilstein 5100's with Eibach spring, 1/2 spacer in driver side and 1/4 spacer on the passenger, Wicked Flow exhaust, Debadge, satoshi raptor grille (HomerTaco)
    do it, mine rides great but I have 5100's all around. With my set up, I thinks it rides better and corners great. TSB is worth it especially when haul alot.
  14. Feb 3, 2011 at 8:47 AM
    Boss 302
    Boss 302 Member
    S.E. Mi.
    TRD Off Road Prerunner
    It will make for a stiffer ride so if you are not planning on towing or hauling heavy loads and you like the soft ride you have now I would say leave it alone. I had mine done and I like the feel of the truck much more than before, like a mattress it was to soft for me!!!
  15. Feb 3, 2011 at 9:28 AM
    DocTaco
    DocTaco Well-Known Member
    Central, KY.
    17 TRD DC Off Road V6 Tow Pkg
    Took mine in yesterday, picked it up last night. I like the new ride, truck feels more solid now. Plus I haul enclosed trailer to and from Florida with sometimes 3 Harleys inside. So I needed the extra springs. Headed back to Fl in March, will only be hauling 2 bikes ...so far... so I expect a much more stable ride than the last trip in Dec.
  16. Feb 3, 2011 at 9:33 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    if they won't do it now just have a aal installed
  17. Feb 3, 2011 at 9:36 AM
    Leggo
    Leggo slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    Do it, it's free.
  18. Feb 3, 2011 at 9:40 AM
    Fed Taco
    Cale
    2011 TRD Off Road
    Don't be a hater because I like free stuff.
  19. Feb 3, 2011 at 10:03 AM
    KevinD
    Kevin
    NC
    This is what I haul[​IMG]
  20. Feb 3, 2011 at 10:17 AM
    Kingfrog
    Kingfrog Well-Known Member
    08 TRD Rugged Trail Edition
    Undercover,Pop n Lock, Hardwired GPS, Garage door opener , Scanguage II, wireless back up camera, X994 Basslink, ...Prefer stock and non invasive functional mods
    Tough question. I was going to get it done "just because" For me that only meant new springs which would raise the already slightly raised rearend ( 08 /24K miles). Apparently the previous owner did not use the bed. Wasn't a scratch on the plastic.
    I decided after opening a case number and speaking with a mechanic to pass. My boat doesn't have the tongue weight to worry about. I towed it with bumper balls and only will tow it a few miles twice a year. Other than that I may carry some yard rock in it once or twice. So rather than having them mess with the truck and screwing up the sweet ride, I decided to pass. The previous owner obviously did not tow or carry heavy loads and did not have it done at a dealership that does them no questions asked where he originally bought it and I later bought it.
    I happen to love the soft ride. Rides better than the Honda Accord Coupe I dumped ...and is quieter as well. I guess if you like the soft ride and don't plan on taking it off road, carrying heavy loads a lot or towing heavy trailers all the time. You really don't need it.
    For those who are getting the whole suspension done free with shocks etc..........yeah I might go for that. Can't blame you guys with Pre Runners. That is a huge upgrade. For me its basically just another leaf. A lot of room to screw things up just to add another leaf.
