Rear Leaf TSB
Discussion in 'Technical Chat' started by tarik88, Nov 26, 2007.
  1. Nov 26, 2007 at 4:56 PM
    tarik88
    tarik88 [OP] Member
    NJ
    07 Tacoma Prerunner TRD SPORT
    hey guys i went to the dealer today and complained saying that my truck was bottoming out when i loaded it up so the tech takes it for a test drive and comes back, next thing i know is i am getting just a new rear leaf pack since i have the trd sport. Now my question is i know the truck is going to sit 1" inch higher in the back so i want to get a leveling kit but will i be able to fit 285/75/17 on there after the tsb is done w/the leveling kit.thanks in advance
  2. Nov 27, 2007 at 2:55 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    i think u'd need a 6" kit to run those 34's. u could fit the 285/70/17's under there w/ the rear tsb and a 2.5" level kit. u'd have to do some trimming in the front even w/ just the 33's under there.
  3. Nov 27, 2007 at 3:10 PM
    tarik88
    tarik88 [OP] Member
    NJ
    sounds good..but which lift kit would you recommend and will a 2.5 make it even or will the front still be raked?...i want my truck to be level...also can i fit the 33" on the trd sport rim which is a 17"...?
  4. Nov 27, 2007 at 3:26 PM
    The_Hodge
    SC
    i'd go either fabtech or toytec...and if u get the reat tsb done and a 2.5" front level, it will be pretty well leveled....maybe a tiny bit taller in the front...and as far as the tires, everything i'm seeing on the net says that u'll need a minimum of an 8" wide rim to support a 285 width...if u could find a 265/75/17, then i think u'd be ok on the rims size for sure
    EDIT: i plan on going w/ a 265/70 on my sport rims in the spring
  5. Nov 27, 2007 at 3:51 PM
    tarik88
    tarik88 [OP] Member
    NJ
  6. Nov 27, 2007 at 4:11 PM
    The_Hodge
    SC
    i'm just going from experience....IE, what i have on mine
  7. Nov 27, 2007 at 5:15 PM
    rick
    rick `
    try a search.. lots of info here. in case you cant find it. i suggest bilstein 5100's up front. as for a 33 inch wheel on your stock rims. nope
