Rear leafs breaking
Discussion in '2nd Gen. Tacomas (2005-2015)' started by boomzoom, Aug 5, 2010.
  1. Aug 5, 2010 at 5:12 AM
    boomzoom
    boomzoom [OP] New Member
    Montgomery Center, VT
    07 SR5 4X4 Long Bed
    Rear Air Lift Package for Trailering
    I have an 07 Double Cab, extended bed, 4x4 Tacoma with 63,000 miles (out of warranty). The spring setup is the three leaf variety. Last year the bottom leaf broke, no apparent reason, although I live in No. Vermont and most of the roads are dirt. I had it replaced. Last week the middle leaf broke again for no apparent reason. Question before repair: Should I just replace this leaf or AAL to help with the overall integrity of the setup. My Taco has not been modified except for air bags when I pull a travel camper (<3,000lbs). Other than the trailer, I don't carry heavy loads. I have heard about the TSB and contacted my dealer. He said to bad basically, out of warranty. I don't want to keep replacing these leafs annually. So any suggestions?
  2. Aug 5, 2010 at 5:16 AM
    Kelson
    Kelson My Truck is Cuter than Yours
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    i would try to find a new leaf pack instead of replacing just one leaf at a time...might help. they aren't that hard to find try and look in a junkyard or something they should run anywhere from $50-$150 depending on who/where you get them from.
  3. Aug 5, 2010 at 5:18 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    X2
  4. Aug 5, 2010 at 5:40 AM
    boomzoom
    07 SR5 4X4 Long Bed
    Thanks for the input. I will definitely consider searching for a new pack.
    Anyone have any luck with Timbrem suspension packs to help out with bottoming out if this is the cause of the leafs breaking?
  5. Aug 5, 2010 at 7:15 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    I would push the dealer a little harder or find another dealer about the TSB. There's been some cases where people have gotten the dealer to eat the parts and paid the labor to install the TSB parts. You'll probably be able to lose the air bags when towing since the new springs are heavier.
  6. Aug 5, 2010 at 10:56 AM
    JKD
    JKD Well-Known Member
    I would go to a spring shop and have them rebuild the spring packs to whatever specifications you want.
  7. Aug 5, 2010 at 10:58 AM
    Pugga
    Massachusetts
    F-150 Mod
    Just a thought, but could the air bags have caused the light duty springs to break?
  8. Aug 5, 2010 at 1:39 PM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    I have broken 5 springs or so in the past 8-9 years - all while the truck has been empty. Its usually the result of a sudden and quick movement in the suspension, such as hitting a pothole or etc.
