Rear leafs feel like they bottom out. What should I replace them with.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Double D 2017trd, Dec 22, 2024.
  1. Dec 22, 2024 at 7:28 PM
    Double D 2017trd
    Double D 2017trd [OP] New Member
    2017 trd off road 4x4
    I have 2.5 fox shocks all around and was fine for a couple years but now it feels like the rear of my truck bottoms out when I go through dips to fast. Not sure if I need to change from the stock leaf springs to something else. Right now I'm only running 265-70 -17 bfg but want to go bigger the next time I need new tires
  2. Dec 22, 2024 at 7:40 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    ^Upgraded leafs won't prevent bottom out if you go through dips too fast. (And if they do, they'd be too stiff for other situations.) Need to upgrade your bumpstops. Wheelers Superbumps are a good choice.
    LOLLY likes this.
  3. Dec 22, 2024 at 8:10 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Go full air bumps. :bikewhoops:
  4. Dec 22, 2024 at 8:41 PM
    Double D 2017trd
    Is it common for this to happen. Two years after I installed the fox shocks or could it be that the shocks need to be rebuilt already. Rears do not have reservoirs and I'm not sure if my leaf springs are just worn out. I will also look into newer and better bump stops.
    Thanks
  5. Dec 22, 2024 at 8:48 PM
    ScrippsRanch67
    ScrippsRanch67 Well-Known Member
    Bob
    06 Tacoma Pre-Runner 2wd Quad Cab short bed
    Fiberglass shell
    Is your year Tacoma subject to the recall to replace the rear leaf springs? If it is still open Toyota will replace for free. Try that first?
  6. Dec 22, 2024 at 9:44 PM
    Double D 2017trd
    Thanks for the info I'll look into
  7. Dec 22, 2024 at 10:19 PM
    LOLLY
    LOLLY Well-Known Member
    Alfredo
    Norwalk, CA
    '05 Tacoma DCLB TRD Sport (RIP) Now '21 TRD Off-Road
    I went with the yellow archive garage bump stops in the rear. Nice and soft at impact.
  8. Dec 23, 2024 at 1:15 PM
    ScrippsRanch67
    Bob
    Fiberglass shell
    I had my rear leaf springs on my 2006 Tacoma quad cab TRD replaced for free a Toyota Dealership under a recall.
  9. Dec 23, 2024 at 1:22 PM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    Share a photo of your leaf springs and bump stop. If there is little to no gap, the leaf springs might just be worn out, and in that case new leaf springs may be just what you need. Blown shocks could also be a problem if they aren't doing their job anymore.
    Chew likes this.
  10. Dec 23, 2024 at 2:43 PM
    Lunchmeat79
    Lunchmeat79 Well-Known Member
    Kansas
    '18 Off Road
    I blew out my OEM rear shocks last spring. Thats what it felt like. It was borderline dangerous hitting expansion joints. Running a 6112/5160 and OME springs, archive garage bumps now. I carry some extra weight and it's so much better. There were visible witness marks from the oem bumps on the frame.
  11. Dec 23, 2024 at 3:34 PM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    Just cause shocks are only 2 years doesn't mean they're still good. Mileage, type of use ,and quality of build all make a difference. I'd check them. Press down hard on each corner to see stiffness and rebound.
