rear leafs need help
Discussion in 'Suspension' started by pudge151, Mar 26, 2011.
  1. Mar 26, 2011 at 8:33 AM
    pudge151
    pudge151 [OP] Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    Ok so i have the TSB rears, 5100s all the way around with fronts at .85" i like the ride and the looks, it looks just about stock with the back a little higher. the issue is when i load the bed up, the rear end still sags a lot, just like before the TSB was done. it does not bottom out as much but still sits very low. and that is with my 1985 Honda ATC 250sx 3 wheeler and some gear in the back, the trike weights 357 lbs so maybe 400# max in the bed.
    i have considered getting air bags, or helper springs, i do not want an AAL because i do not want lift or rough ride all the time. i have heard that the helpers do not make the ride stiff when unloaded but also heard that they do?
    i know that air bags are ideal for me but also they are not cheap, any experience with the Helper Springs? i have searched and only found a handful of threads on them, most were about how they were used for axle wrap.
    thanks
  2. Mar 26, 2011 at 9:13 AM
    raycie
    raycie Well-Known Member
    Oahu, HI
    2013 DCLB / 2016 4R Trail
    In need of $$$
    I just installed a set of timbrens on the truck. I know that wheelers also came out with a similar product that also replaces the factory bumpstops. Will be carrying a small load this morning.. Will see how they ride and perform.
  3. Mar 26, 2011 at 12:06 PM
    pudge151
    Sean
    Connecticut
    yeah my 4 leaf TSB is flat to almost frowning when NOT Loaded
  4. Mar 28, 2011 at 7:21 AM
    pudge151
    Sean
    Connecticut
    help please?
  5. Mar 28, 2011 at 7:24 AM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    Firestone has a decent set of air bags
  6. Mar 28, 2011 at 7:30 AM
    Cogge89
    Cogge89 Well-Known Member
    Justin
    Saint John, NB
    09 Tacoma TRD Sport
    Pioneer AVH-P4100DVD, Kicker ZX400.1 Amp, Kicker CVT 10" Sub. Light Racing UCAs, Front OME Shocks with 885x Coils, Rear OME Shocks with Dakar Leaf Pack, Engine Cover Paint Job, 265/70/17 Duratracs.
    I use the Firestone Ride-Rite air springs on my truck. I use them to raise the rear of my truck with bilsteins at 1.75" in the front, the ride is a little stiff at 15psi(unloaded). But if you're looking to match it with .85", they should be absolutely fine. My 4 leaf pack had sagged a lot from my atv, so this was my solution. If you have any specific questions, feel free to post them, or pm me. I'll help the best I can.
  7. Mar 28, 2011 at 7:30 AM
    Sheppymach
    Sheppymach Well-Known Member
    Sheppy
    Philadelphia, Pa
    2014 4Runner trail edition
    BLU LOGIC bt, avid, weather tech mats & rain guards, 285/70/17, BenWA's totally AWESOME power sliding window mod.
    get a 2" AAL and take out the 3rd leaf toyota put in and replace it with the 2"
  8. Mar 28, 2011 at 9:30 PM
    pudge151
    Sean
    Connecticut
    thanks guys. i think airbags is my best option but i just dont want to spend that much for occasional use, i might have to bite the bullet, i do not want an ALL because i dont want any lift or a much stiffer ride
    any experiences with helper springs? i hear Hellwig is ok
  9. Mar 28, 2011 at 10:31 PM
    raycie
    Oahu, HI
    In need of $$$
    less than a week with the timbrens, but I think they are an awesome product.
    the only caviot is that they need to be setup properly... They say that you should have an inch (empty bed). I don't know if I had more or less than an inch (bed empty) cause I am not looking forward to taking off my shell just to measure.
    with nothing else in the bed, I do hit a little stiffly over speed bumps.. But with some additional weight in the bed it is pretty darn awesome...
    if I had it higher or lower by 1/2" I think I would be awesome loaded or unloaded...
