Rear leafs
Discussion in '1st Gen. Tacomas (1995-2004)' started by chazjb, Apr 2, 2011.
  1. Apr 2, 2011 at 11:41 AM
    chazjb
    chazjb [OP] Well-Known Member
    James
    Oregon
    2015 DCSB Sport
    Hey guys looking to replace my rear leafs in my early 97. I have been looking into Northwest Off-Road's leafs as they are a direct fit. Any one have either of their packs in your Tacoma? I don't like the current flat leaf because i camp a lot in the summer and add a lot of weight which makes a negative arch. I don't want to do airbags and don't want an AAL. Ive looked at all-pro but the springs from them for my truck involves me having to weld on new hangers which I don't want to do either. I have a 3" shackle lift in the rear now but have the factory shackles still so a lifted spring wouldn't be a problem to replace. I spoke with Wheelers yesterday and they said that their 4/5 leafs are not meant to carry much more weight and they still are flat.
    I do a fair amount of wheeling but am looking more for some leafs that will carry the added weight and still give me my 3" lift. Also im in the process of building a rear bumper that all said and done will weight around 200lbs so it would need to support that weight.
    Thanks in advance for your thoughts.
  2. Apr 2, 2011 at 11:44 AM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Have you considered the Dakars ?
    Edit : I just noticed you have a '97 , and I'm not sure that the Dakars work with that year .
  3. Apr 2, 2011 at 8:33 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    D'OH!!! just missed the Wheeler group buy! couldve got a 5 pack
    But i would recommend the Allpro expedition 8 pack leafs. from what i have seen, they give you a very good lift and also will hold 400lbs extra supposedly. Check out Jlee's build, he got them and loves them. barely sag when on a trailer but still flex good
  4. Apr 16, 2011 at 4:53 PM
    chazjb
    James
    Oregon
    2015 DCSB Sport
    Alright guys so I decide I'm going to go with NorthWest Off Road heavy duty replacement leaf since there is no mods needed for my truck like the allpros require. The NWOR leafs say they give you an added 700lbs payload over stock so we will see. I'll post some before and after pics when they come in.
  5. May 26, 2011 at 11:32 AM
    Rdeeker
    Rdeeker Member
    05 TRD Offroad
    I'm looking at the NWOR springs for my '05... What did they cost you?
  6. May 26, 2011 at 11:44 AM
    bobbyinbend
    bobbyinbend Member
    Bobby
    Bend, Oregon
    04 Tacoma Xtra Cab TRD
    grey wire, 2lo, output flange, king coilovers, allpro expedition leafs, bilstien 5150, gemtop commercial canopy, sleeping platform, dual battery, water tank, fridge, propane, BFG mk2, trail gear bumpers, warn m8000
    Why would you have to weld anything with the allpro expedition leaf pack? i didn't, bolted right in.
    As far as i know only if you get the Ubolt flip kit would you have to weld, otherwise it will bolt right in.
  7. May 26, 2011 at 11:59 AM
    richsteele
    richsteele Member
    99 Reg cab 2.7L 4x4
    Dash & heater panel LEDs, stereo & speaker upgrades, 2004 side mirrors, Safe-T-Cap mid-frame section repair kits.
    On the Allpro springs for 95-97 trucks, you have to mount the front spring hangers 2" forward and the rear shackle hangers 1" back. 98-04 will bolt right in.
  8. May 26, 2011 at 12:01 PM
    bobbyinbend
    bobbyinbend Member
    Bobby
    Bend, Oregon
    got it, should have read his post more carefully would have noted the 97.
    thanks!
