Rear leaves sagging
Discussion in '5 Lug' started by maverick4x2, Apr 15, 2023.
  1. Apr 15, 2023 at 6:03 PM
    maverick4x2
    maverick4x2 [OP] Well-Known Member
    2013 Tacoma 5 lug
    Evening gents, hopefully a quick question. My 5-lug has some serious squat in the back, has been developing for a few years; its starting to annoy me. I'd estimate a negative rake of about an inch. Given that the truck started with positive rake id assume a drop of 1.5-2". I have a cap and keep approx 100lbs of gear in it; not a real heavy load for a truck, so im confused as to why they are already giving up the ghost. My question is, is it better to replace the whole leaf pack or add a leaf?
  2. Apr 15, 2023 at 6:17 PM
    Homeline
    Homeline Well-Known Member
    2013 Access Cab 5-Lugger
    2" Leveling Kit, TRD skid plate, 16" Jeep wheels, Katzkin leather seats w/heaters, jump seat delete
    Given that you have topper, I think AAL be the best economical approach.
    Alternative to that would be air bags.
  3. Apr 15, 2023 at 6:20 PM
    GeoTaco
    GeoTaco the town is back that way
    Freeda Feltcher
    Denverish
    '21 Army Green TRD OR DCSB
    Car seats
    I put in sumo springs before I replaced the whole leaf pack
  4. Apr 15, 2023 at 7:06 PM
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    My vote is a long aal and new rear shocks.
  5. Apr 16, 2023 at 4:38 PM
    maverick4x2
    2013 Tacoma 5 lug
    thanks all, i'll shop around for an aal, sure is way less expensive than a full pack. I had never heard of sump springs until it was mentioned here, its an interesting design, wouldn't have thought to look for anything like that
  6. Apr 16, 2023 at 4:43 PM
    Bishop84
    Bishop84 Well-Known Member
    AAL on an old spring set will just sag again, it will lift it up for a month max, then sag right away. Save your money for a pack.
    Sumo springs work on sagging or new springs so its a better choice as interm. Make sure its for a 5 lug axle over spring if you do go that route.
    Homeline likes this.
  7. Apr 16, 2023 at 4:48 PM
    Travlr
    Travlr Lost in the ozone again
    Middle'a Utah
    2012 Baja Series Access Cab
    Last time I ordered stock springs they were less than two hundred dollars per side from Rock Auto.
  8. Apr 16, 2023 at 6:40 PM
    Homeline
    That's a good point about old springs re-sagging again.
    I'm curious, will springs from a 6-lug bolt onto a 5-lugger?
  9. Apr 16, 2023 at 9:13 PM
    5 Lug Fury
    Kenny
    Knoxville, TN
    Yes and no. Yes it will bolt it but it has no arch compared to the 5 lugs since its spring over vs spring under.
