Rear led tail lights not working properly
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Roho, Dec 12, 2023.
  1. Dec 12, 2023 at 5:24 PM
    Roho
    Roho [OP] New Member
    2008 Tacoma Prerunner
    2008 Tacoma led taillights not working properly. Checked fuses, replaced the two bulbs that is replaceable. Replaced sensor inside behind brake pedal. Parts store said left circuit board bad so I Ordered same assemblies for both sides, replaced, still same problem.
    Problem: turn signals both work. When lights are on, neither brake light works. Right side lit up as if riding the brake. Left side nothing. In the daytime w lights switched off, I have right side brake light only, left side nothing. Feeling disgusted after spending $275 on new assemblies that didn’t fix the problems. Any suggestions would be appreciated. Is this probably a simple fix that local shop should be able to handle or anything else I could try myself? I’m not too mechanically inclined myself and really hoped the assembly replacing would fix this.
  2. Dec 12, 2023 at 5:54 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Considering they get power and ground from the same source it would seem you have one or more broken/corroded wires or a bad ground at Ground Point BD.
    Jimmyh, Too Stroked and TnShooter like this.
