Rear left turn signal brighter than taillight
Discussion in '1st Gen. Tacomas (1995-2004)' started by byrdthomas4x4, Mar 15, 2019.
  1. Mar 15, 2019 at 3:46 PM
    byrdthomas4x4
    byrdthomas4x4 [OP] New Member
    Thomas
    2004 toyota tacoma sr5 4x4
    When i turn my lights on. My left turnsignal comes on solid and stays on. Im wondering with it
  2. Mar 15, 2019 at 3:48 PM
    cabowabotacoma
    cabowabotacoma Well-Known Member
    Rob
  3. Mar 15, 2019 at 3:50 PM
    cabowabotacoma
    Rob
    Trying to think of something but I gotta face it - I ain’t good with that
  4. Mar 15, 2019 at 4:00 PM
    jbrandt
    jbrandt Well-Known Member
    Sacramento, CA
    '04 TRD Tacoma 4x4 DC
    King ext travel coils Total Chaos UCAs Sticker mod
    Has this always happened as far as you know, or is this new?
    Have you done some work to it recently?
    My bet is it's a short in the wiring, or maybe a bad switch. Do the turn signals work with the lights on?
  5. Mar 15, 2019 at 8:53 PM
    byrdthomas4x4
    Thomas
    The right side works fine but the left side just stays lit and doesnt work
  6. Mar 16, 2019 at 3:37 AM
    RysiuM
    RysiuM Well-Known Member
    Rysiu
    Was Golden State, now Poland EU
    1995 4x4 LX Ext Cab, I4 2.7, MT, 320K miles
    DD Deck+backup camera, LED DRL, All LED except H4 Hella
    Standard question: do you have trailer harness adapter installed? If they go bad, they can do $hit to lighting.
    cruxofthebisquit likes this.
  7. Mar 16, 2019 at 3:41 AM
    knayrb
    knayrb Well-Known Member
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    Have you replaced the bulb? It could be cracked and air got in. The filament is burning away. $2 easy try.
  8. Mar 16, 2019 at 3:46 AM
    RysiuM
    Rysiu
    :confused: Wut?:confused: What does that have to do with the price of tea in China?
  9. Mar 16, 2019 at 4:23 AM
    Btoz
    Btoz Member
    Brent
    1998 Tacoma 2004 Tacoma 2008 Tacoma 2008 4Runner
    Nothing really
    Check and/or add a ground at the left rear tail light at terminal 3, White/Black wire. If the lights operate correctly, you can make the ground permanent or trace the White/Black wire. I have seen the 4 flat trailer converter boxes cause all kind of weird crap, if you have one, remove it first then check bulbs.
  10. Mar 16, 2019 at 4:54 AM
    Troyken
    Troyken Well-Known Member
    NY
    2013 DCSB v6 off road 4x4 6 spd. MT
    Remove any convertor plugged into trailer light socket if equipped and recheck. Then liberally flush out the socket with WD-40. It could be a bad convertor and /or corrosion in the socket itself. If no trailer socket, check tail light sockets and bulbs for corrosion and clean as required with power OFF. If you have added any aftermarket LED bulbs remove them first and reinstall original bulbs and recheck.
