Rear left wheel won’t align
Discussion in '3rd Gen. Tacomas (2016-2023)' started by PamDV, Jul 20, 2022.
  1. Jul 20, 2022 at 11:05 AM
    PamDV
    PamDV [OP] New Member
    Tacoma 2021
    We took our 2021 Tacoma (we are the sole owners) for its first alignment and the technician was concerned because the rear left wheel won’t budge from 0.34°. The right shows 0.01°. He is concerned because it’s a fixed rear axle and this issue should not exist. The truck has never been in an accident or hit anything. Why would this be? Could it have been wrong from the time of the vehicle was made? I am taking it to a Toyota dealership tomorrow but I really want to understand this. It is 23,000 miles on it.
  2. Jul 20, 2022 at 1:41 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome to TacomaWorld
    DrFunker and buckhuntin-tacoma like this.
  3. Jul 20, 2022 at 1:45 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!
  4. Jul 20, 2022 at 1:57 PM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    First alignment? What does that mean lol. It's not a thing you should normally need to have done annually. Why are you taking it in to get aligned? Did you make any suspension changes or hit a excessive amount of curbs/potholes that upset the front alignment?
    Solid axle w/ leaf packs does not have any adjustable parameters for aligning. The only way might be to loosen the axle from the u-bolts or the leaf packs from the truck and try to move it while on the rack but I doubt it would make much difference since it's kind of set in it's ways. This is pretty common on Tacoma's and seems like an acceptable amount of error per Toyota. That amount of toe difference should be able to be compensated for up front to get you a better thrust angle, the front is very adjustable.
    Mark77 likes this.
  5. Jul 20, 2022 at 2:02 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    It will never move. Don't worry about it so much, it's not a big deal.
    Mark77 likes this.
  6. Jul 20, 2022 at 2:03 PM
    Mastiffsrule
    Mastiffsrule Well-known member, but no one cares.
    Scott
    2021 Taco XP Predator
    You recall hitting a curb at some point, possibly bending the axle? Why is the tech concerned it will not budge, it should not be adjustable like IFS. He appears to know that as you also mentioned. He should be able to tell you the problem. A good alignment tech should be able to diagnose your problem.
    Maybe find a new shop?
    Rock Lobster likes this.
  7. Jul 20, 2022 at 2:05 PM
    Trail Limo
    Trail Limo Well-Known Member
    It's a solid axle. Toe on a particular tire does not matter and the technician should adjust the front to match the rear. What is total toe on the rear? As long as total toe is within spec you are good.
  8. Jul 20, 2022 at 3:32 PM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    I have a 2017 and still rock the factory alignment.
  9. Jul 20, 2022 at 7:44 PM
    ernscott
    ernscott Well-Known Member
    2021 Tacoma
    Get your second opinion. It happened to me on a small bus that I sub-framed after it was in a bad accident. I knew everything was right on the money and the owner took it to a tire chain store for an alignment a year or so later, and they told him it was way out. He complained to me, which made me think the worst. When we re-checked it -- it was still right on the money. The shop admitted that they made a mistake setting it up on their rack. I was angry, but relieved cause I really felt the welds might have separated. Regards and welcome to a great forum !!!
  10. Jul 20, 2022 at 7:52 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Thrust alignment...
    Take it somewhere that knows what they're doing.
  11. Jul 20, 2022 at 7:56 PM
    Bishop84
    Bishop84 Well-Known Member
    Some alignment machines read wrong, sometimes they read right.
    0.34 should be somewhat visible. That said, there's no real specification for the rear. It's just a tube with axles bolted to it.
    Warranty is unlikely even if it reads the same on their machine. It's likely just a small deviation on the axle tube causing it.
    Corollas are famous for this with their dead axles, none of them are straight, but being a dead axle, it doesn't really matter.
    TnShooter likes this.
  12. Jul 20, 2022 at 8:40 PM
    PamDV
    Tacoma 2021
    Well you have all made me feel better . I took it in because 1. I am likely out of touch and thought that vehicles need aligned on a regular basis like the old days 2. I saw it looked like wear on the outer edges of the tires and realized we had had the vehicle for over a year and not aligned it.
    I’m taking it to the Toyota dealership tomorrow. Hopefully it don’t tell me something crazy like my axle is bent. I mean we have had no accidents so that would be kind of ridiculous but nothing surprises me anymore.
    Thank you again! I am a huge Toyota fan ..
    Have Owned Circle, Corolla‘s and a 2007 Sienna that I still have. I have always dreamed of a Tacoma and plan on keeping it for a good 20 years or more
  13. Jul 20, 2022 at 8:47 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I wouldn't expect the dealer to say much of anything seeing that it's still fairly new and under warranty.
    My money is on a alignment rack sensor that wasn't properly hung. Try a different shop
  14. Jul 21, 2022 at 5:21 AM
    ernscott
    2021 Tacoma
    On a stretch - your U-bolts could have been slightly loose causing the center bolt to shear - but that is something you would see and also, not a hard fix.
  15. Jul 21, 2022 at 5:29 AM
    JTfromWV
    JTfromWV Active Member
    WV/VA border
    2022 AG TRDOR 6mt
    I had a center bolt shear on a 85 Toyota. It was very noticeable. It would also affect alignment on both rear wheels.
  16. Jul 21, 2022 at 5:35 AM
    Clearwater Bill
    Billy
    Largo Florida
    Is this alignment place you used a big box (Firestone/Goodyear etc) per chance?
