rear license plate light assemblies
Discussion in '2nd Gen. Tacomas (2005-2015)' started by piercedtiger, Nov 14, 2012.
  1. Apr 12, 2013 at 4:56 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    Do you know why your light socket has melted? Or that bulbs blow when you plug new ones in? Might want to look into this....;)
  2. Apr 12, 2013 at 6:34 AM
    piercedtiger
    piercedtiger [OP] Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    For me, I'm assuming the bulb burned out due to the corroded, shorted, melted contacts. As for why that happened, the clear lens part had a crack so maybe water got in?
