Rear Lift Airbags?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tooltime, Feb 12, 2012.
  1. Feb 12, 2012 at 8:53 AM
    Tooltime
    Tooltime [OP] Member
    Scott
    Atlanta, GA
    12 Tacoma TRD Double Cab Sport LB
    Step bars, 2" front leveling kit, 265/70R17, Factory Roof Rack, Bakflip F1 Bed Cover
    Hi Folks, first time Toyota owner and so far I am loving my Tacoma 4x4 TRD sport 4 door long bed. One of the first things I did was raise the front 2" to level it out and put some 275/75's on it to give it a real 4x4 look. Now that I am caring around tools and stuff, the rear is now lower than the front by an inch. When unloaded it is perfect. Rather than adding a 1" block to the rear which would be to high when not loaded, I was thinking about adding an air lift so I could adjust the level depending on the load. I really don't want to compromise the ride because this baby drives soooo nice. Don't see much out there on this topic unless I am not doing something right. Any information would be greatly appreciated.
  2. Feb 12, 2012 at 9:06 AM
    Johns Taco
    Johns Taco I'm not 4x4, and have an open diff. So i'm 4x1
    Albuquerque, NM
    05 DSM Base SR5 Slug Taco
    Full custom stereo, onboard air compressor, train horns, spacer lift, 30" tires, optima yellow top, rear slider window & tailgate anti-theft mod, pop & lock, class 3 tow hitch, lights in bed, Ultra Gauge, Weather Tech mats, yellow fog lights, camper top, air lift rear airbags, rear diff breather mod, soon to be more...
    I did it just to get rid of the sag I had from my worn leaf pack, was real a straight foward install and works good. Can carry a lot of weight now with no sag. If I could do it again I would have paid the extra money for the Firestone kit, hope this helps. Welcome to the forums! :)
  3. Feb 12, 2012 at 9:37 AM
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    3" lift, custom rims, snug top shell, shrockworks bumper, warn winch.
    The Firestone kit is easy to install. Easy to use.
    The kit suggests putting the air valves in or under the bumper. I put them in the bed inside the cubbies--only a suggestion. As a reminder, you need to run with at least a minimum amount of air in them--something like 15psi.
    Here's what it looks like:
  4. Feb 12, 2012 at 10:00 AM
    acdronin
    acdronin Well-Known Member
    I installed firestones, love em, I installed the air valves, one on either side of the 7 pin connector under the bumper, pretty easy install, took out the spare tire and jacked up the rear so i had enough space to crawl under and zip tie the air lines to the frame rails.
    I recommend them
  5. Feb 12, 2012 at 11:57 AM
    badger
    badger Well-Known Member
    07 SR5
    I ran the Firestone bags in my truck for about 18 months. They work very well! I've since upgraded my spring pack and will probably be taking mine out. If you mostly run light, but need to compensate loads for hauling or towing they are really great. The minimum is 5psi, not 15. The maximum is 100psi, but I never used more than 50. At 5psi you can't tell they are there. Good product. They are easy to install too. If you go to the Firestone RideRight website, all the instructions are downloadable
  6. Feb 12, 2012 at 12:04 PM
    Faryota
    Faryota Well-Known Member
    Mic
    Ridgefield, WA.
    13, 4x4, long bed, Sport, Debad
    6" BDS lift in front, warn winch, AFE cold air intake & exhaust, Body Armor Rear bumper, Tuffy in bed storage box, DZ bed mat, ARB front bumper & Warn winch w/light kit, Husky floor mats, dash mat,
    Welcome...and I too am thinking the Firestones!!!
  7. Feb 12, 2012 at 12:05 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Why not just replace the rear shocks with air shocks?
    That's what I was told by someone who seemed to know what they were talking about.
    I'm still debating what to[​IMG] do. Any suggestions would be appreciated.
  8. Feb 12, 2012 at 12:24 PM
    badger
    07 SR5
    Does anyone make an airshock for the Tacoma? I don't believe anyone does, but if so I'd like to know.
  9. Feb 12, 2012 at 2:54 PM
    Tooltime
    Scott
    Atlanta, GA
    Great feedback guys. I am an old hot rodder and remember air shocks were VERY stiff. When pumped up, they road like a truck (no pun intended).
  10. Feb 12, 2012 at 3:08 PM
    badger
    07 SR5
    If you use them just to jack the back of the car up, like we did back in the day, ..... yep a bit stiff. If you use them to compensate a load it's probably better, but I doubt as good as an airbag. It's been a LONG time since I've riden in an air shocked vehicle though.
  11. Feb 12, 2012 at 3:17 PM
    GrayTacoma
    GrayTacoma Well-Known Member
    Andy
    Huntingtown, MD
    2011 TRD off road
    PIAA ion yellow fogs stay on all time,aux reverse lights, aux lights, camper with rack, cb, air bags, on board air, aux fuse box, aux batt, CAI, etc.............
    I have the firestone bags on my truck, it helps alot pulling my heavy trailer. Really easy installation.
  12. Feb 12, 2012 at 3:20 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    the only problem i see with airshocks instead of airbags is: 1 I don't think the mounts for the shocks are cabable of handling lifting the truck or supporting extra weight as they are only for absorbing shock and not weight. 2 is I think airbags would benefit more because they are seperate and are designed for leveling trucks and heavy loads.
    just my .02
  13. Feb 12, 2012 at 4:13 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    I'm not planning any heavy towing. I wonder, if the air shocks would help cornering; if it stiffens the truck that much perhaps I could do without the Hellwig rear sway bar? That would be nice to accomplish things with a simple air shock replacement; Ride, Handling and simplicity. All I ever wanted to do was keep it simple.[​IMG]
  14. Feb 12, 2012 at 4:59 PM
    Polymerhead
    Polymerhead Well-Known Member
    Missouri
    '10 4x4 DC SR5
    WeatherTech liners, Kenwood Media Receiver, Alpine S 6x9 speakers, Sound Ordnance 8" Sub, OEM running boards, MK6 wheels, Dynapro ATs, Tint, Bed Mat, Avid Light Bar, Rigid 20" LED bar, Truxedo Lo Pro Tonneau Cover
    Note:Once the air helper springs are installed, it is recommended that the vehicle not be lifted by the frame, as over-extension may occur, resulting in damage to the air helper springs. However, should it become necessary to raise the vehicle by the frame, deflate both air helper springs completely.
    Is this a problem if you go get your truck serviced?
  15. Feb 12, 2012 at 6:07 PM
    Polymerhead
    Missouri
    '10 4x4 DC SR5
    Right - so you have to request that they do this I assume? The mimimum psi is 5 lbs for normal use, so I guess you would drive to the dealer and then deflate or tell them to make sure and deflate& inflate after.
  16. Feb 12, 2012 at 7:00 PM
    Utard
    Utard Well-Known Member
    Mark
    Nyssa, Oregon
    2012 DC LB 4WD TRD SPORT NAVI
    ------------------------------------------------------------ Stabilus.EZDown.Tailgate http://www.ezdown.com/home.php ----------------------------------------------- Tekonsha.Primus.IQ.Trailer.brake http://www.tekonsha.com/content/default.aspx---------------------------------------------------------------- Leer 180 CC http://www.leer.com/Truck-Caps#------------------------------------------------ Firestone Air Rite Air Bags--------------------------------------Kargomaster Rack
    I have had them on an 06 and a 12. I love them. When you have a load in the bed they really keep you from rolling very much. Like a tall quad in the back.
  17. Feb 12, 2012 at 7:07 PM
    badger
    07 SR5
    Actually, those are good points! The shock mounts are definitely not up to it. Maybe that is why I've never seen them for the taco.
  18. Feb 12, 2012 at 7:47 PM
    IndianTaco
    IndianTaco Well-Known Member
    ive been thinking about air bags aswell. hows the off road performance like flex with air bags?
  19. Feb 12, 2012 at 10:06 PM
    acdronin
    The only thing I noticed off road is that when the rear is flexed, it looked like i could tear a bag is i pushed too far, I plan on getting straps to limit the travel some
  20. Feb 12, 2012 at 10:13 PM
    Tigahshark
    Tigahshark Senior NEWBIE
    Isaac
    On a volcano, literally!
    2011 DC TRD off road 4X4
    Tint Weathertech floor liner, weathertech window visor Roll n lock tonneau cover Rubber bed mat Smoked license plate covers
    Aloha OP
