Rear lift block? Why not(on road use)?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by im4u2nvss, Mar 24, 2017.
  1. Mar 24, 2017 at 5:29 PM
    im4u2nvss
    im4u2nvss [OP] Well-Known Member
    Jesse
    2012 DC
    I can understand that a rear lift block may not be great for offroad use but is there any real reason to not run them on the street? I added a 1" ready lift rear block to my truck and so far I have not noticed any down side. I would have went with the icon or wheelers AAL but I only wanted 1"(not 1.5"). I remember a ford superduty that I previously owned had about a 4" block from the factory, and that was a heavy 1 Ton truck. I was following a 2017 superduty yesterday and it appears that they are still using a rear block from the factory. Any comments on the topic would be appreciated.
  2. Mar 24, 2017 at 5:38 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Not much of a concern for street.....
    However - depending on what the block is made of (say for instance, alluminum) - you'll want to check the Ubolts periodically to make sure they're still tight.
    Alluminum is soft - so over time due to vibrations & pressures - the alluminum can possibly flatten/deform in shape reducing their overall height which can leave your ubolts loose.
    I've seen this countless of time with the offroading guys. Same scenario - just might take longer to get there.
  3. Mar 24, 2017 at 5:42 PM
    im4u2nvss
    Jesse
    2012 DC
    The ones I bought were cast steel. Any real concerns on checking torque after the 500 mile check?
  4. Mar 24, 2017 at 5:44 PM
    Artruck
    Artruck Well-Known Member
    Lawrence, KS
    '09 Super Basic
    I would mark the bolts with a paint pen, just for piece of mind.
  5. Mar 24, 2017 at 5:48 PM
    Janster
    Jandy
    Lancaster, PA
    That would depend.....If you check them at 500 miles and nothing was loose - then you're probably OK for a while. But...don't take my word for it. It's your truck.....
    If you find they're a little loose at 500 miles, I'd tighten them and check them again in 500 miles.
  6. Mar 24, 2017 at 6:06 PM
    NordidiroN
    NordidiroN Well-Known Member
    Ron
    Georgia
    '15 DCSB SR5 4x4
    Retrax MX Pro bedcover, Avid bumper gaurd, Predator step rails, Aux D rings, Door sill protectors
    Wondering the same. What about cast steel 1" blocks? :notsure:
    Anyone with experience have problems with these?
  7. Mar 24, 2017 at 9:05 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    I've had aluminum blocks in my truck for over seven years with no problems.
  8. Mar 25, 2017 at 12:27 AM
    NordidiroN
    Ron
    Georgia
    '15 DCSB SR5 4x4
    What size?
    And do you ever go off-road?
    (I know that wasn't the OP's original question)
  9. Mar 25, 2017 at 5:50 AM
    Janster
    Jandy
    Lancaster, PA
    I also had 2 degree alluminum axle shims under my 96 tacoma for at least 5 years without issues....
    But I have known friends who had issues with aluminum. It could be any variation in the product or even the installation too. You just never know. If I had to do it again (any type of shims or blocks) - I'd get cast.
  10. Mar 25, 2017 at 5:53 AM
    Colgan
    Colgan Well-Known Member
    I recently added 1" cast iron blocks to the back. Haven't noticed any issues yet. Just keep an eye out on the ubolt nuts.
  11. Mar 25, 2017 at 6:19 AM
    spiralout462
    spiralout462 Well-Known Member
    Eastern Shore VA
    2015 4x4 dclb
    Icon suspension '15 toyota nav TRD FJ SE anthracite wheels Weathertechs Trd pro pieces
    The 2015 I bought came with a 2" block in the back. I immediately ordered and installed a set of Dakar springs. I found it interesting that the centering pin on the passanger side had kind of wallowed out of the axle. Don't know whether to blame it on the block or loose ubolts. The axle was definitely out of whack though.
    Moral: check ubolts torque whenever possible!
  12. Mar 26, 2017 at 5:02 PM
    sparkystaco
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    1" billet with 3*shim
    Not as much as I'd like to.
    NordidiroN[QUOTED] likes this.
  13. Mar 28, 2017 at 10:29 AM
    dirtnsmores
    dirtnsmores A camping truck
    Southern California
    06 DCLB Prerunner
    OME885/5100, DAKAR MED-DUTY, SOFTOPPER
    If I add a 1" block to my setup that already has a 1.5" single AAL... will I need longer shocks? Currently running the standard length 5100s
  14. Mar 28, 2017 at 4:08 PM
    sparkystaco
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    That's kind of a double edged sword; you can but it's not recommended
    can) but the shock will be very close or topped out leaving no drop in the axle, I'm doing it but I knew this going in.
  15. Mar 30, 2017 at 2:38 PM
    Janster
    Jandy
    Lancaster, PA
    As for the shocks - Do you do any offroading? If not...chances are, you can run the shocks you have now without maxing them out on compression/extension. If you're curious - here's a site that explains how to measure your vehicle for proper shock length. There are others out there....
    http://www.off-road.com/trucks-4x4/determining-shock-length-18665.html
  16. Mar 30, 2017 at 7:40 PM
    dirtnsmores
    Southern California
    06 DCLB Prerunner
    Thanks for that article and info. Most likely going to save up and get a new leaf pack and shocks. Just do it right. Yep I like hitting easy/moderate trails
  17. Mar 30, 2017 at 7:45 PM
    Bishop84
    Bishop84 Well-Known Member
    General consensus among all truck owners is 1" blocks are fine. Any bigger and you get wicked axle wrap and you need new shocks.
    Most of the 4"+ lifts that are cheaper use a 1" block with an AAL and longer shocks.
    I've never seen an issue with them, the older tacos broke springs with and without the block.
