Rear lift blocks or Add a leafs...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jeremy15, Dec 28, 2017.
  1. Dec 28, 2017 at 6:09 PM
    Jeremy15
    Jeremy15 [OP] Well-Known Member
    Jeremy
    Boone NC
    '12 Tacoma Prerunner
    I am installing 1.75’ blisteins on my tacoma and I want it to have a leveled out look. For the rear I’m looking to add an inch at the most and I don’t know if blocks or an AAL is the best option. This truck is not used for any off-road or hauling so it would be for looks only.
  2. Dec 28, 2017 at 6:12 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    My truck stock
    My truck with Bilsteins set at (approx) 1.75
    With 1.5 inch add a leafs from Wheelers Offroad.
    I would ALWAYS suggest avoiding blocks.
  3. Dec 28, 2017 at 6:21 PM
    Jeremy15
    Jeremy
    Boone NC
    That looks nice. I heard the add a leafs will wear down and eventually the truck sits at stock height? How long have yours lasted?
  4. Dec 28, 2017 at 6:36 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Just did mine a few weeks ago. Mine are just there for now, till I get different wheels and bigger tires. I will go with a full spring pack to lift it again.
    If all you are looking for is the lift of 1.75 front and 1 back... with no wheeling... you should be fine with just AALs. You could also go with Progressive AALs. They are a little more money, but supposedly last longer.
    My AALs are just place holders because I needed new shocks, wanted Bilstein rears and had to lift 1 inch in the back so I didn't damage the rear shocks.
