Rear lift dilemma
Discussion in 'Suspension' started by malander, Feb 7, 2011.
  1. Feb 7, 2011 at 7:43 PM
    malander
    malander [OP] Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    Alright guys I've been saving up for some all-pro leaves to replace my current aal but I'm having second thoughts.
    I don't tow alot or even that often but every summer I haul maybe 10 loads or so of mulch or rock around town. I would like to achieve 3"-3.5" of lift in the rear to get me back to factory rake as well. I don't want to go with blocks or shackles but they look like my last option.
    I would go with the all-pro expo pack but it states that it will actually give you 4"-5" of lift unloaded and other than the occasional summer towing job I don't think those will be necessary.
    So this got my creative juices flowing. I recall a while ago that someone had put some junkyard coils in-between the bump stops in the rear on top of the leaves. Now I have a bit of an issue with half assing things but this idea makes the most sense to me. If I recall correctly the poster in that thread had no issues with the coils being compressable to the point of coming off of the bump stops and load carrying capacity and ride quality improved.
    Is this my only alternative? If so has anyone else done this? Also if anyone knows what thread I'm talking about post up a link! I've been searching all night and I want to make this work if it is deemed "safe" by you guys.
  2. Feb 7, 2011 at 7:45 PM
    S.B.
    S.B. Well-Known Member
    Sean
    Colorado Springs, CO
    08 Taco 4x4 TRD OffRoad Rugged Trail
    Fox 2.5, Built right UCAs, CBI Front bumper, NWTI Rear bumper, 35s
    You could do air bags in the rear instead of the coil springs.
  3. Feb 7, 2011 at 7:49 PM
    malander
    max
    01 limited trd 4x4
    I had thought about that but i don't know how well those will cater to my needs. I forgot to add that I would like something that will still flex decently and I don't know much about bags by I will do some research, thanks for the suggestion
  4. Feb 7, 2011 at 7:50 PM
    S.B.
    Sean
    Then forget the bags if you offroad and flex.
  5. Feb 7, 2011 at 7:52 PM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    Just get the regular 3" all pros
  6. Feb 7, 2011 at 7:53 PM
    malander
    max
    01 limited trd 4x4
    Ah well I appreciate the suggestion
  7. Feb 7, 2011 at 7:57 PM
    malander
    max
    01 limited trd 4x4
    I would I just don want to get them and wear them down in 2 years because when I do tow its usually around 2000 but at times I've done loads up to around 4500. I'm really starting to like this coil idea... Someone get me to believe the expos will work without turning my truck into a stink bug haha. To anyone with the standard ap leaves: how often and how much so you tow and what are the affects on your springs?
  8. Feb 7, 2011 at 8:00 PM
    kinkrider101
    santa barbara
    wheels and tires
    I have just a aal. I tow about 2k pounds 2 times a month. And my aal is still doing great!
  9. Feb 7, 2011 at 8:05 PM
    malander
    max
    01 limited trd 4x4
    Shit I can't even tell I have an aal lol
  10. Feb 7, 2011 at 8:07 PM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    go ome dakar pack...they have overload leaf
  11. Feb 7, 2011 at 8:12 PM
    malander
    max
    01 limited trd 4x4
    I had thought about one but after seeing that box rocket didn't seem to have the load carrying capacity he wanted I'm shying away from that option. I don't want to get a leaf pack AND a block or extended shackle
  12. Feb 8, 2011 at 1:51 PM
    malander
    max
    01 limited trd 4x4
    I think I found my answer
    http://www.northwestoffroad.com/parts/2stage.html
    Anyone ever use these springs? They state 2" of lift which is a bit shy of my goal but with 750 lbs more carrying capacity over stock an a supposedly good ride on and offroad Im starting to like this idea. I can always throw in a 1" shackle later
  13. Feb 9, 2011 at 5:36 AM
    malander
    max
    01 limited trd 4x4
    Morning bump. Anyone have experience with these?
  14. Feb 9, 2011 at 11:18 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    I have a set of those that I used for about 5K miles and took off. They gave me more lift that I wanted, about 3.5" over stock. Even though they are designed for load carrying, they still flexed pretty good.
    Send me a PM if you think you might be interested in them. I want to get rid of them, just collecting dust.
  15. Feb 9, 2011 at 12:50 PM
    FlyingWil
    FlyingWil Well-Known Member Vendor
    Wil
    Sonoran Desert
    01 DC Expedition Ready
    Shrockworks Front Bumper, LightForce 240's, PIAA 510's,T-Max 9000 competition winch with Outback (longer drum) and modified brake wireless controller and Masterpull line with Viking safety thimble, Rugged Ridge Hawse, Daystar Winch isolator, SAW Racerunner 2.5 coilovers, Safari Snorkel, IBS dual battery system with RBM, Scangauge II, Total Vision self spotting kit and monitor with aux output and remote, Low Tek Gauge pod with Cyberdyne gauges for fridge and battery, Yeasu FT-7800 head unit mounted in ceiling linner and speaker Larson Hood mount, Uniden Pro 520XL CB radio in the ash tray location,'lil Wil Mag mount antenna, Odessey 1200 MJT & Die Hard Plat. dual batteries, Can-Back with extra mounts, Blue Sea 12 st Fuse Box, 100 Amp 100 Amp Relay, Extremeaire & 5 Gal air tank w/ 145 psi switch, Custom bed drawer system, Engel Mt-45 with TwoZone, protective covers, and Engel Slide Eezi-Awn 1600 RTT w/ Ikea LED light mod, and sheet set, CBI offroad Expedition rear bumper, jerry can tir
    Oh man. I have been there and done this. I would give you my opinion, but can't since I am a vendor. I would definitely go with the OME Dakars as CRF mentioned above.
    If you end up adding more weight down the road, you can add an AAL.
    You would need CS046RA and CS046RB for the first gen Taco. If you end up needing the AAL down the road, D6XL would be the AAL's for the spring pack above.
  16. Feb 9, 2011 at 5:49 PM
    malander
    max
    01 limited trd 4x4
    Alright so I called up nwor and this is how the conversation went....
    Me:Hey I was just wondering how much the stage 2 lift springs are and if they were in stock
    Anonymous guy: Oh yeah we just got them in after being 18 months out of stock
    Me: Awesome
    Anonymous guy: yeah they come in at about 275 a p...
    Me: AWESOME
    Anonymous guy:...iece
    Me:F*wwwwkkk alright well how much will shipping be to Missouri? I can't imagine it's cheap.
    Anonymous guy: It looks like that will be around 100-110
    Me: DOUBLE F*wwwwkkk
    so when i add it all up it looks like this
    a set of stage 2 leaves $550+tax
    shipping $110
    extended brake lines $40+tax+shipping
    new u-bolts $40+tax+shipping
    install ? I'll estimate $150
    so total is 890+ shipping and tax.
    no way in hell im spending that much money.
    Hopefully I will be able to work out a deal with Digiratus and if that doesn't work out I will probably end up going with the dakars
  17. Feb 9, 2011 at 5:57 PM
    FlyingWil
    Wil
    Sonoran Desert
    Seriously go with the Dakars... I am speaking come from experience. I have had All-pro, Deavers, Alcan, and am now on Dakars.
  18. Feb 9, 2011 at 6:08 PM
    toyo freak
    toyo freak Another Toyota Enthusiast
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    5100s at 2.5, Wheeler 3 leaf progressive AAL, Weathertech liners, yellow wire mod, toyota OEM bed mat, cup holder mod, afe pro dry s air filter, UWS low pro toolbox, Escort radar detector
    ^^^what he said.
  19. Feb 9, 2011 at 6:08 PM
    toyo freak
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    What lift do you have in the front?
  20. Feb 9, 2011 at 6:09 PM
    malander
    max
    01 limited trd 4x4
    I know they had some quality issues in the past but I assume they have been fixed since... is this correct?
