Rear lift Height
Discussion in '1st Gen. Tacomas (1995-2004)' started by ssoulssurfer, Feb 15, 2020.
  1. Feb 15, 2020 at 7:33 PM
    ssoulssurfer
    ssoulssurfer [OP] Well-Known Member
    1998 Tacoma 4x4 SR5 TRD MANUAL TRANS 3.4L V6
    2.0 FOX COILOVERS FRONT, 5100 BILLSTEINS REARS
    This may be difficult to answer, I understand this but...
    Does anyone know what the rear stock height is on a 1st gen (1998 4x4 V6 TRD), from the center of the wheel, to the bottom of the fender well with the plastic fenders?
    Anyone with stock leaf springs that have perhaps been replaced instead of the 200-300 worn springs on there?
  2. Feb 15, 2020 at 9:27 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I need to learn to read correctly.
    :popcorn:
  3. Feb 15, 2020 at 10:09 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Very bottom of this post has stock and lifted ride heights (center of hub to bottom of flare) for my 2000 Tacoma, which should be the same as your '98. Front and back measurements there; shout if you have questions.
    https://adventuretaco.com/the-boss-lift-prepping-for-armor/
    The height of the truck will vary with what you're talking about here, but from center of hub to bottom of fender will be the same regardless of wheel, tire, wear, etc. because the relationship of the rear axle to the body is only affected by the leaf springs (well, and any other "lifty stuff" like blocks, body lift, etc.)
    Kwikvette[QUOTED] likes this.
  4. Feb 15, 2020 at 10:10 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Oof lacking reading comprehension tonight.
    I'll remain as an audience member for the rest of the night.
  5. Feb 16, 2020 at 7:23 PM
    ssoulssurfer
    Ok awesome thanks. Sounds like it's about 22" then. My new deaver's I just put on were getting close to 25", so def gotta break'em in.
