Rear Lift Help
Discussion in 'Suspension' started by GeauxTigers, May 19, 2012.
  1. May 19, 2012 at 11:20 PM
    GeauxTigers
    GeauxTigers [OP] //TRD
    Caleb
    Sterlington, Louisiana
    '14 TRD DCSB Off-Road 4x4
    265/70/17 BFG KO2/17"x7" Pro Sema Wheels/OME 884/Bilstein 5100 front & rear/HeadStrong 1/4" TP spacer/Deaver 1.5"-2" AAL/Mud-Flap delete/Westin Bed mat/UltraGauge/ WeatherTechs/AFE Pro Dry Drop in Filter/debadged/AVS in-channel window visors/color-matched OEM grille/Kicker 6.75" Components in front door/Alpine KTP-445U power pack behind factory head unit/
    So a while back I installed a 2.5" spacer lift to my truck and left the back stock (no tsb spring). The rear sags a little bit so I'm wanting to get the back level via AAL. Any suggestions as far as 1.5" or 2"? Good brands? I'm wanting the truck to be level, and don't want the rear higher than the front. Thanks!
  2. May 21, 2012 at 7:24 AM
    GeauxTigers
    Caleb
    Thanks for the input. Wasn't aware that Deaver offered an AAL. I'll check it out!
  3. May 21, 2012 at 12:08 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
  4. May 21, 2012 at 6:31 PM
    GeauxTigers
    Caleb
    thanks for your replies, fellas!
