Rear lift options with 886x
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wobble, Mar 20, 2013.
  1. Mar 20, 2013 at 1:39 PM
    wobble
    wobble [OP] Well-Known Member
    Ridgefield, WA
    2014 TRD OR
    Modified RCD Lift, 315/70R17 STT Pros
    First post, go easy on me :D
    Previously had 5100s set at 2.5 and ToyTec AAL in rear (non-TSB). It sat slightly high in the rear.
    I just installed 886x coils up front and Apex bumper w/winch. Obviously the front sits slightly nose high now. I thought about buying some used TSB springs, but can't seem to find any. What other options are there for gaining another 1/2" or so in the rear without spending a fortune on custom spring packs? (I occasionally haul firewood and do weekend off-roading)
    Thanks
  2. Mar 20, 2013 at 2:12 PM
    BradyT88
    BradyT88 Well-Known Member
    Welcome to TW:D
    Everyone might bash me for this, but 1/2" blocks would probably be easiest and likely cheapest since you already have an AAL. I have 886's on 5100's set at 0 with a plate bumper and the TSB leaf packs with a 1.5" AAL and still have some bro lean...
    Other than blocks the only other option I can think of is the one you mentioned. Aftermarket leaf packs, like Allpro expos or OME DAkars.
  3. Mar 20, 2013 at 2:14 PM
    Large
    Large Red
    ^ That's what I would suggest for a band aid until you want a leaf pack.
  4. Mar 20, 2013 at 2:25 PM
    wobble
    Ridgefield, WA
    2014 TRD OR
    Thanks for the info! I looked for some 1/2" blocks for a simple fix, but didn't have much luck. Any idea where I could find some?
    At this time, $400 max.
  5. Mar 20, 2013 at 2:27 PM
    BradyT88
    That would pretty much get you some Dakars or the Expo pack. Just need a little more and some shipping.
  6. Mar 20, 2013 at 2:43 PM
    Blygy
    Blygy Well-Known Member
    East of Edson
    Supercharged 2012 DCLB TRD Sport Trail Teams
    Trail Teams Edition Supercharger
    Junk Yard leaf packs built your self.. Cheap and quite easy really..
  7. Mar 20, 2013 at 2:46 PM
    Large
    Large Red
    With the Dakars you'll need new shocks, and the shipping cost is relatively expensive
  8. Mar 20, 2013 at 3:18 PM
    wobble
    Ridgefield, WA
    2014 TRD OR
    I didn't even think about needing longer shocks. Looks like the extra 1/2" is gonna cost me quite a bit more than I figured.
    Are these the correct springs? I think the stated 2.5" lift should get me where I want to be. Are shock extenders an option for my existing 5100s or are they not a good idea?
  9. Mar 20, 2013 at 3:22 PM
    Large
    Large Red
    ^ that's them, you'll need 4 OEM bushings and new U-bolts as well for a full install. Not sure if shock extensions are available for the 5100s, but you won't break a shock just daily driving.
  10. Mar 20, 2013 at 7:28 PM
    wobble
    Ridgefield, WA
    2014 TRD OR
    Thanks for the responses guys. I took a closer look at my rear springs. They lay flat, somewhat arched downward. Only the center and ends of the AAL make contact with them. It appears as though the stock springs are pretty worn. I think dakars are the best bet. How is the ride with them?
  11. Mar 20, 2013 at 9:33 PM
    Raceline08
    Raceline08 Well-Known Member
    Brett
    Santa Rosa, ca
    Silver 08 DBC SB 4x4 TRD Offroad
    front Billies, 885x coils, taco lean spacer, TC UCA'S, Magnaflow 22" OME Dakars, Billy 110 rear's, B.A.M.F CMC, custom made E-locker guard
    I went with the dakars, great springs. I also bought 5100s with extenders. Long story short I hated the way the extenders looked and they might be fine to some people but for me they were half ass and I wanted it done right. I junked that set up, well sold it and bought the b110 shocks they work great. You have to modify your bumpstops but a longer shock for sure.
    With the dakars, stock length 5100s and extenders the shocks were maxed out .
    Brett
  12. Mar 21, 2013 at 7:22 AM
    wobble
    Ridgefield, WA
    2014 TRD OR
    Wheelers states the springs are 2.75" over stock. (Part # CS047)
    Toyteclifts states the springs are 2.5" over stock. (Part # CS047R)
    Is there a difference between the two part numbers?
    I want to make sure it won't sit higher than I'm looking for before spending the money. Raceline08 and Beavis0076, do you have any side pics of your trucks? If not, how does it sit with 3" up front and the dakars in the rear? (level, slight rake, etc)
  13. Mar 21, 2013 at 7:27 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    OMD 4WD Chevy spring addon.
  14. Mar 21, 2013 at 7:28 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    The Dakars will , on average get you 2.5" of lift over stock on a DC
    If you current leafs are really flat it may seem like more
  15. Mar 21, 2013 at 7:33 AM
    Raceline08
    Brett
    Santa Rosa, ca
    Op there are some pics in my gallery of my truck with the dakars , the last pic is a side shot, yes slight rake which I like. A load of firewood in the back and it sits level. Let me know if you can see the pic ? I'm doing all this from my phone.
    Thanks
    Brett
  16. Mar 21, 2013 at 7:41 AM
    wobble
    Ridgefield, WA
    2014 TRD OR
  17. Mar 21, 2013 at 7:51 AM
    Raceline08
    Brett
    Santa Rosa, ca
    You got it dude!
    Brett
  18. Mar 21, 2013 at 8:13 AM
    OZ-T
    Peter North
    British Columbia
    Wait , wut
    What do you have in the rear of your truck now ?
  19. Mar 21, 2013 at 8:33 AM
    wobble
    Ridgefield, WA
    2014 TRD OR
    2" ToyTec AAL
  20. Mar 21, 2013 at 9:56 AM
    wobble
    Ridgefield, WA
    2014 TRD OR
    Thanks Beavis0076. That's exactly the look I'm after.
    I just called Wheelers. They said it's the same spring, they just didn't put the "R" in the website description.
    Wheeler's recommends a carrier drop bracket. Did you guys install that with your Dakar leafs?
    Now for shocks...how much stiffer is the ride with NitroCharger sport shocks (60091) vs standard NitroCharger shocks (N182)?
