Rear lift problems
Discussion in 'Suspension' started by raycie, May 30, 2010.
  1. May 30, 2010 at 9:51 PM
    raycie
    raycie [OP] Well-Known Member
    Oahu, HI
    16 T4R Trail
    In need of $$$
    Had a 1.5 aal installed. Started making that really bad squeaking noise so brought it back to the shop to have them take a look at it. They lubed it with white lithium and off I went. Squeaking started again, so I brought it back. They ended up grinding a bit off the ends and relubing it.. Noise went away for 2 days, but came back again. Called the shop again, and they are willing to change out my aal for a 1 or 1.5 in. block. I don't do any off roading, but do load up the bed every once in a while.
    Options.
    1. Keep the aal and try to relube again. And wait for the next leaf pack group buy.
    2. Let the shop install the block and go with that.
    3. Purchase the toytec or wheelers aal (comes with cut ends and anti-friction pads) let the shop off the hook, and install myself.
  2. May 30, 2010 at 10:53 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    1. Reinstall same AAL: pressurewash leafpack, spray down with lube, reinstall correctly.
    3. Those 'anti friction' pads on the Wheelers etc AALs are in the spots where the noises come from, so that's also a good alternative.
  3. Jun 1, 2010 at 2:37 PM
    OH-MAN
    OH-MAN Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    If the AALs you purchased did not have the friction pads that is most likely where the squeek is comming from.
    The grease will not last longer than it took to drive off the lot.
  4. Jun 2, 2010 at 8:09 AM
    Toytec Lifts
    Toytec Lifts Toyota Suspension specialist Vendor
    Rocky Mountains
    Toyota's are awesome
    Go for the new ones. :)
