Rear lift Q
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SD Scott, Apr 10, 2016.
  1. Apr 10, 2016 at 10:11 AM
    SD Scott
    SD Scott [OP] Member
    The common question........blocks or AAL for a slight rear lift. My '13 DC 2.7 is now 1.75"-2" lifted in the front with 5100s. As I drive the truck 500 miles/week, I will be using the stock 245/75/16 Dunlops 90% of the time. I have an extra set of rims and plan to put 265/75/16 Mickey Thompson Baja STZs on for when I want to do some exploring. So, I need the truck to look OK with the stock size tires. It now has a negative 1" rake now. Since I do use the truck for occasional Home Depot runs and very infrequently tow a trailer, I'd like a slight rake. So with a target of 1-1.5" in the rear I am thinking AAL. The ICON AAL progressive kit is a 3 leaf pack. Could I remove 1 of the leafs if the lift is too high? I have a 2 & 1 rear leaf pack. Does this matter?
    Thanks for the input
  2. Apr 10, 2016 at 11:32 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    The stock 2+1 leaf pack is shitty at best unfortunately. That stated an AAL will be the best as it will give you some more spring rate.
    Grab the wheelers 3 leaf AAL, its cheaper but essentially identical to the icon.
  3. Apr 10, 2016 at 11:40 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
  4. Apr 10, 2016 at 1:10 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
