Rear Lift...TSB AAL or Dakar Leafs
Discussion in 'Suspension' started by jmed99, May 11, 2010.
  1. May 11, 2010 at 6:19 PM
    jmed99
    jmed99 [OP] Well-Known Member
    SC
    09 DC PreRunner TRD OR
    I'm wanting to go with the Toytec ULK and I have an 09 TRD DC OR Prerunner. I'm wanting a 3" lift up front and I want the back about 1" higher. I have the TSB performed.
    Will the Dakar leafs give me a higher rear than the TBS AAL? Again I want to be about 1" higher in the rear. Will I need to extend my brake lines?
    Thanks! :D
  2. May 11, 2010 at 8:34 PM
    yosh2000
    yosh2000 Well-Known Member
    Denver, CO
    '17 Tundra CM 5.7
    dakars all the way. may give a little more than the TSB w/ AAL, but your load capacity will thank you w/ the dakars. mine ride like a dream on sucky socal fwys too! you will want extended brakelines.
  3. May 12, 2010 at 9:51 AM
    jmed99
    SC
    If I get the TSB AAL and the rear is level with the front, could I add a 1" block to get the rear 1" higher than the front?
  4. May 12, 2010 at 9:54 AM
    yosh2000
    Denver, CO
    '17 Tundra CM 5.7
    ^ thats the way it works...but again, i would highly suggest getting the dakars and not mess around....
  5. May 14, 2010 at 4:00 PM
    Racer78
    Racer78 Well-Known Member
    05 Tacoma 4X4 Sport
    Billstiens 5100 @1.75, 5125, 1.5 AAL,Leaf Spring TSB,TRD Intake, Roof Rack, Satoshi Grill, BHLM,T-Rex Eyelids, Undercover Cover, Powdercoated Sport Rims, KC Slimline 8" Lights, MTX ReQ5 w/ipod imput, 12" Shallow Pioneer Sub, RF 800.4 amp, JBL Comp, Bed Ext, USB Port, Shorty Antena, Spider Trax Spacers,TRD Skid Plate, Napier Sportz Tent II, Scangauge II, AirBedz
    Do you think you will need to extend the brake lines for the TSB route with just the AAL?
  6. May 14, 2010 at 4:40 PM
    yosh2000
    Denver, CO
    '17 Tundra CM 5.7
    i do not believe so, but new lines are only like $60 through crownperformance.com. dont let that detour you from getting the OMEs...you will be disappointed, i guarantee you.
  7. May 14, 2010 at 5:17 PM
    Racer78
    05 Tacoma 4X4 Sport
    Cool, I'm running the non tsb's with a 1.5 aal. Still looking sorta sacked out so I picked up a set of next to new tsb's for cheap to replace them. Going with the Toytec 1.5 tsb aal so should give me a tad more hight.
    Thanks
  8. May 14, 2010 at 5:25 PM
    yosh2000
    Denver, CO
    '17 Tundra CM 5.7
    ^ but your carrying capacity is still going to suck...
  9. May 14, 2010 at 6:44 PM
    Racer78
    05 Tacoma 4X4 Sport
    The current setup now isnt too bad with the aal. I tossed a few loads of top soil in the back last week and for what it was...it worked out. I can live with something slightly better so thats what im hoping for with the new TSB setup. A bit more hight and some more weight capacity is what im hoping for..
    thanks for the info!
