rear lift with all pro pack
Discussion in '1st Gen. Tacomas (1995-2004)' started by crazyjeys, Sep 28, 2010.
  1. Sep 28, 2010 at 11:08 AM
    crazyjeys
    crazyjeys [OP] Well-Known Member
    Chino Hills, CA
    2018 TRD Off Road 4x4
    been saving for a new leaf pack now. was thinking if anyone has tried out the all pro packs? i'm not hauling stuff, so i don't mind the weight capacity. but are they good? also, thinking of getting the 3 inch lift? will that level up with the 5100's set to 2.5 at the front? and would i need extended brake lines as well? i don't go wheeling. just want the lift. thanks in advance for the inputs.
  2. Sep 28, 2010 at 12:08 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Typically with 2.5" of lift in the front, to make the vehicle sit level, you need to lift the rear about 1.5". 3" of rear lift will really make the rear end sit higher.
  3. Sep 28, 2010 at 12:12 PM
    mjp2
    Milton Juevos Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    I ran All Pro leaf packs on my 2nd gen truck for awhile and was really happy with them. Quality product, and the guy I sold them to is still running them without complaint.
  4. Sep 28, 2010 at 7:58 PM
    Johnnie
    Johnnie Well-Known Member
    I.E. SoCal
    Feds
    I've heard a lot of good reviews about the All Pro leaf packs and that's what I plan on buying when the time comes. However, if you're not going to wheel, why don't you just get some lift shackles and save yourself about $400.You don't need the extended brake line but for less than $30, may as well buy it and not have to worry about it.
  5. Sep 28, 2010 at 8:44 PM
    crazyjeys
    Chino Hills, CA
    If only i could do shackles. But i think my leafs are going to go soon. That's why i wanted to replace it with a new pack. Any other suggestions on what i can do to remedy this situation? One side of my leafs are almost flat but the other side seems still okay. Do you think AAL's can still fix it?
  6. Sep 28, 2010 at 8:48 PM
    Johnnie
    I.E. SoCal
    Feds
    AAL's might help. I've been running shackles for about 2 years now and I've done plenty of wheeling and they're flat but with the shackles I'm able to maintain my lift. IMO, since you don't wheel I'd get shackles or an AAL. If you're a frequent wheeler then get leafs.
  7. Sep 28, 2010 at 8:56 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    You can get the OME 2.5" leafs. Those are nice too. I love my AP 3" leafs though. Either way is good.
  8. Sep 28, 2010 at 8:58 PM
    STLharry
    STLharry Lube: It's the key to penetration.
    Harry
    VT
    Yeti Rescue Package with 270k miles
    '95-'97 camouflaged, ARB bull bar, RAT Products skid plate kit, sliders, Green Mountain Customs rear tube bumper and overland bed rack, King coilovers with Icon neoprene covers, defenestrated sway bar, OME Rear Suspension: CS046R leafs + AAL/5125 shocks/NWOR greasable hardware/U-bolt flip kit; S13WL Tundra calipers/pads/rotors, IPF H4 lenses and bulbs, IPF 968 DCG 100W lights, clapped out CB radio, Aussie-spec FJ60 inclinometer, ARB CKMA12 compressor, Superwinch S9000 with 12V Guy clock switch, 4' Hi-Lift, deckplate mod/grey wire mod/dif breather extensions, Duratrac tires, Sockmonkey bedside decals, boat cupholder, Dakine bike pad
    So you crawl around various blacktop surfaces outside malls? :D:D:D:D
    No point in lifting if you don't wheel...worse mpg's, more wear on parts, less power (w/ larger tires).
  9. Sep 28, 2010 at 10:04 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2012 DCLB
    Grillcraft mx black upper and lower BHLM with Gloss black 265 70 17 bfg a/t center console light mini mag mounted in center console debadged bed lights 35W 5000k HID's
    there's nothing wrong with having your truck look a little more manly.
    and OP, I did an AAL in the rear with my 01 with saggy leafs, it worked great, but I am getting some axle wrap.
