Rear lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacoma guy, Aug 2, 2016.
  1. Aug 2, 2016 at 8:20 AM
    tacoma guy
    tacoma guy [OP] Well-Known Member
    Joe
    Phoenix Az.
    2011 Tacoma Prerunner TRD
    Bilstein 5100's on all four corners. Front set @ 0 with OME 883x coils. Alcon leaf springs. Viper Alarm. Wet Okole seat covers. WeatherTech Floor liners front and back. Oem Toyota chrome exhaust tip. ARE Shell. America Outlaw Wheels.
    Need your help guys . Ok so I want to lift the rear from stock to 1 inch on my 2011 TRD off road prerunner . I have the OME 883's up front and I am sitting level and would like to put just a like rake back . My question is will I developed a vibration?
  2. Aug 2, 2016 at 8:22 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Maybe yes maybe no. Each truck is different.
  3. Aug 2, 2016 at 8:50 AM
    tacoma guy
    Joe
    Phoenix Az.
    Yeah kind of what I was thinking.
  4. Aug 2, 2016 at 9:13 AM
    TacoRph
    TacoRph How 'bout them Dawgs
    2015 MGM TRD OR 4WD
    I'm curious as well... I'm thinking about installing a 1.75 inch lift up front (TRD Pro suspension), and an aal pack in the back with the overloads left in, which should raise the rear by about 2 inches. I have zero experience with this sort of thing, but I'm hoping I won't experience any vibrations by raising the front and rear about the same amount. I'm probably way, way off base here...
  5. Aug 2, 2016 at 11:55 AM
    tacoma guy
    Joe
    Phoenix Az.
    That's about what I went up in front and it was fine. It leveled me out with the rear. I found a couple of threads that are saying that they have hed issues with raising the rear 1 1/2in and up but nothing on 1in. :confused:
  6. Aug 2, 2016 at 12:23 PM
    keith88lx
    keith88lx Well-Known Member
    Mount Prospect
    15 DCSB TRD Sport 4x4
    As much as I hate to admit this, I did the 1" blocks in the rear from Toytec. I have not experienced any vibrations, but then again I do't go offroad. I didn't notice any ride difference. The blocks just helped level me out since I have Fox coilovers up front.
  7. Aug 2, 2016 at 12:32 PM
    Nighthawk
    Nighthawk 'streme spoats
    Levi
    Casper Wyoming
    2008 Red TRD OR AC V6
    Bilstein 5100's w/ Eibach coil overs in front (set at 3" of lift). Front diff drop kit. Extended Bilstein 5100's in the rear. Deaver 2" AAL in rear w/ axle shims. 285 x 75 r 16 Goodyear Duratracks. Wheelers steelies type B, AFE cold air intake. Sway bar delete. All Pro Apex front bumper (rattle canned Rustoleum primer + flat black). Plasti-dipped emblems. Mud flaps removed.
    It doesn't matter that you raise them the same amount, it changes the drive line angles and that causes vibration.
    The best way to deal with vibrations is to lift it to where you want it and then see how bad it is, there are lots of things you can do to minimize the vibes.
    OP, I'm thinking that with just 1" of lift in the rear you will be OK, but like 5150 said you just never really know until you do it.
    Unchained 5150 likes this.
  8. Aug 2, 2016 at 12:54 PM
    tacoma guy
    Joe
    Phoenix Az.
    Yeah its my daily driver and I don't off road as well. But 5150 and Knighthawk are right every truck is different. Thanks guys for all the reply's .
    Much appertained !
  9. Aug 2, 2016 at 6:14 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Not sure what 1" lift options there are for the rear other than blocks. Blocks cause axle wrap and should be avoided if possible. Using the 3 leaf progressive AAL (sold under many names; Toytec, Wheelers, Icon, Headstrong Offroad I think offers it now too) gives 1.5" lift with the overloads removed and a much improved ride over stock. For minimal lift, that is the route I would suggest. I did not get vibes going up 1.5" in the rear.
    Here is the results of my Baja lift with the 1.5" AAL:
    https://www.tacomaworld.com/threads/baja-tx-pro-kit-icon-aal.385619/
    Capt. Obvious likes this.
  10. Aug 2, 2016 at 6:42 PM
    rmepilot
    rmepilot Well-Known Member
    Rob
    Huntsville, AL
    '23 LR DCSB TRD OR 4x4 Premium Pkg
    2019 Jeep GC Summit 5.7l '15 DCLB S/C 4x4 Limited Pyrite Mica - Deceased
    I was seriously considering this option, however you may want to look at the Fox Level 2 lift from Headstrong, for the same amount of $$.
    With that said, I'm still looking for what will suit me best, but leaning toward the Fox Lvl 2.
    http://www.headstrongoffroad.com/store/p199/FOX_Level_2_Kit -_05__Tacoma.html
  11. Aug 2, 2016 at 6:45 PM
    TacoRph
    2015 MGM TRD OR 4WD
  12. Aug 3, 2016 at 1:50 AM
    runner05
    runner05 Well-Known Member
    Karl
    Another vote on using rear blocks. Inexpensive and effective if you want a raked look.
  13. Dec 13, 2016 at 3:48 PM
    tacoma guy
    Joe
    Phoenix Az.
    Ok so what are my chances of getting vibrations if I only lift the rear 5/8 in ? Also if I use a steel figure 8 block would I have any issues with the block cracking or would the sold T-6 aluminum block be better then the steel figure 8 block ?
  14. Dec 13, 2016 at 4:56 PM
    rmepilot
    Rob
    Huntsville, AL
    I went 2" AAL, zero vibes.
    1.5" AAL's are inexpensive through @HeadStrong Off-Road. Much better idea than a block. YMMV
    HeadStrong Off-Road likes this.
  15. Dec 13, 2016 at 5:00 PM
    rmepilot
    Rob
    Huntsville, AL
    I did the AAL pack w/ overloads left in and got a full 2" and stiff ride. I like it, but just a bit stiffer than I wanted. Not worth the labor of pulling them out though.
  16. Dec 13, 2016 at 5:09 PM
    tacoma guy
    Joe
    Phoenix Az.
    Yeah I can't do an AAL. I have the Alcan 8 leaf custom ones . I just need 5/8 in. to level me out .
  17. Dec 13, 2016 at 6:16 PM
    rmepilot
    Rob
    Huntsville, AL
    Oh ok. check with Marie, I think she has rear spacers for that.
  18. Dec 13, 2016 at 6:50 PM
    tacoma guy
    Joe
    Phoenix Az.
    Spacers ? Do you mean rear lift blocks ?
  19. Dec 13, 2016 at 7:00 PM
    Pigpen
    Dan
    Northwest Montana
  20. Dec 13, 2016 at 7:00 PM
    rmepilot
    Rob
    Huntsville, AL
    It's an OME item (1/4 thick and can be stacked). ask Marie @HeadStrong Off-Road and see if she can help.
