Rear lifting blocks from Speedway motors
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Roadglide1550, Jun 7, 2021.
  1. Jun 7, 2021 at 7:00 AM
    Roadglide1550
    Roadglide1550 [OP] New Member
    Is anyone using the Speedway Motors lift/lowering blocks to lift the rear and do you like them? I am about to install Bilstein 5100 all around with OME 884 coils up front for a 1 inch lift on 2018 Limited, would like to keep a small rake so 1/2 or 3/4 inch blocks seem about right. Also going to put on Bridgestone Dueler A/T Revo 3 265/65/18 tires for an overall mild 1 1/2 inch lift.
  2. Jun 7, 2021 at 9:46 AM
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    Blocks are blocks for the most part. Use quality u bolts/nuts and check/re tq after a couple hundred miles and not a bad idea to check them again every now and then.
  3. Jun 7, 2021 at 11:09 AM
    Roadglide1550
    Thanks it’s just that options for blocks less than 1 inch are extremely limited.
