rear lights
Discussion in '1st Gen. Tacomas (1995-2004)' started by Donald512, Dec 29, 2023.
  1. Dec 29, 2023 at 9:36 AM
    Donald512
    Donald512 [OP] New Member
    Hello
    OK Im baffled how can I have running lights work and brake lights work but when the running lights are on I dont have brake lights?
    Don
  2. Dec 30, 2023 at 9:54 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    What was the last thing you did to the truck just before the brake lights stopped working?
  3. Dec 31, 2023 at 7:53 AM
    Donald512
    So my brake lights do work. I don't understand when my running lights are on the brake lights don't work and when there off the brake lights do work. I get conflicting messages from this board. As I said I have 95 tacoma 2 wheel. I'm making it to a flatbed. I'm trying to use led lights. This where I get conflicting messages, can I use LED? or because I have a dual element bulb does that preclude using LEDs. Also someone put trailer light connector on it but they did not use a converter box just tapped into the wires just twisting wires and duct tape. They mostly broke. I took the trailer wiring out and temp fixed the breaks in the wires. Another thing I don't understand is Tacoma uses ground switching instead of switching on the power side, is that accurate? Thank you very much for replying much appreciated
  4. Dec 31, 2023 at 8:14 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Given the history of your vehicle, I think you’d be helping your and our sanity by making a drawing of what you’ve got.
    I have LEDs on my flatbed, it’s totally doable. I don’t believe our taillights are ground switched, you get wires for tail, l/r turn and reverse from the front of the truck, and then one ground for all.
    I used a trailer light converter to combine turn and brake for the LEDs since I didn’t have a good way to add amber turns to mine.
  5. Dec 31, 2023 at 8:42 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
  6. Dec 31, 2023 at 9:54 AM
    Donald512
    Thank you so much fro replying. I have to run now but I will get some specific details, so I can ask better questions. Thank you
    Bivouac likes this.
