Rear Locker in 2 and 4 high
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Truky!, Feb 26, 2020.
  1. Jul 22, 2020 at 10:03 PM
    #81
    GladiatorNOT
    GladiatorNOT Well-Known Member
    2017 TRD OR
    Old Man BP51 coilovers Dakar HD leaf springs Icon Delta control arms TRD Pro rims with Kenda Klever RT 33x10.5 tires Exhaust mod TRD front skid, RCI tranny and transfer case skids Southern Style Slimline front bumper Baja Designs S8 bumper light Warn Zeon Platinum 10s winch 4.88 Nitro gears ARB front locking differential ARB twin air compressor X2 Power 27 battery RCI rear bumper with Rigid SRQ lights RCI rock sliders RLD canopy Dometic CFX3 55 refrigerator TRD Pro grill Front & Rear anytime camera Seat Jackers Diode Dynamics Pro fogs
    Ok makes sense. Thanks for the explanation.
    doublethebass[QUOTED] likes this.
  2. Jul 22, 2020 at 10:16 PM
    #82
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    It matters. Force is not torque. Horsepower is not torque nor force and power is a different concept. Let's stick to torque and speed for now.
    Speed and torque are totally different and this is key to understanding differential operation.
    Locker = Equal speeds, unequal torques (torque may be equal but is not required and the torque bias can be from 0% to 100%)
    Open diff = Equal torques, unequal speeds (speeds may be equal but are not required to be but the average of the 2 output speeds must always equal the diff carrier speed)
    Correct
    ONLY equal speed is applied, equal torque is not.
    The original statement was 4H vs rear locker. Rear locker binds the rear and the rear axle is a simple, strong unit without many fragile parts and typically carrying less weight and easier to slip to relieve bind. In 4H the entire system binds both front and rear. The front is the more fragile system with CV joints, steering joints, and steering duties and will typically be harder to scrub and relieve bind because it is the heavier end of the vehicle. So rear locked you bind just the rear and in 4H you bind the front and rear. Binding front and rear is worse than binding just the rear. If you want to change the conversation to 4H compared to front locked that's a different story and a new discussion and not the discussion originally started.
    I've explained it enough at this point. I've experienced both and dd'd spools and auto lockers. Tight turns in 4wd on pavement is brutal, I don't do it. With the rear locked in 2wd I'll do it. I don't care. ***Just because speeds can vary from left to right in 4H it doesn't mean each side can achieve the ideal speed.*** This is because the open diffs must still operate inside the parameters they're constrained to which is the input speed from the tcase (I'm literally blue in the face from saying this). Since these ideal speeds can't be achieved by the combination of a locked tcase and open diffs you get scrub and bind in 4H. Since you're getting bind in the front and rear parts of the system it's worse than just getting bind in the rear alone.
    Synopsis:
    4wd binds everything. Bad.
    Rear locked 2wd binds the rear only. Bad, but not as bad.
  3. Jul 22, 2020 at 10:22 PM
    #83
    GladiatorNOT
    2017 TRD OR
    Okay nice summary ShimStack. Thanks for enlightening me on the subject.
  4. Jul 22, 2020 at 10:23 PM
    #84
    ShimStack
    Ben
    NC
    *face palm* Son of a....... I give up. Have fun guys!! :thumbsup:
  5. Jul 22, 2020 at 10:38 PM
    #85
    doublethebass
    doublethebass aspiring well-known member
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    Hey, it’s late!
    Edited.
  6. Jul 22, 2020 at 10:39 PM
    #86
    deanf
    deanf Well-Known Member
    Dean
    '16 Tacoma TRDOR & '15 4Runner Limited
    Because some of the guys in these 4x4 forums are like "I won't turn my 4WD system on until the very last second (and probably too late) because . . . " [shuffles deck] " . . . I might wear it out."
  7. Mar 19, 2021 at 7:11 PM
    #87
    MickeyB
    MickeyB Well-Known Member
    '17 TRD OR 6MT 4x4
    Mobtown skids and sliders
    Any progress on the original question?
    I just hate shifting into 4Lo with the stupid dial. That’s my reasoning for wanting a locker in 4Hi. Obviously Toyota does it with the 2WD TRD OR’s, so it can be done (that’s aimed at Toyota, not you! Lol)
  8. Mar 19, 2021 at 7:13 PM
    #88
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    MickeyB[QUOTED] likes this.
  9. Mar 19, 2021 at 7:21 PM
    #89
    MickeyB
    '17 TRD OR 6MT 4x4
    RedWings44[QUOTED] likes this.
  10. Mar 19, 2021 at 8:32 PM
    #90
    ShimStack
    Ben
    NC
    I am making progress on mine. I'm now on plan C. Similar to what's been done so far but with an indicator light and no power resistor. It will work like having an aftermarket rear locker as far as the truck's ecu's are concerned.
