Rear locker not engaging
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoWave, Jun 27, 2017.
  1. Jun 27, 2017 at 2:52 PM
    TacoWave
    TacoWave [OP] Well-Known Member
    Adam
    2017 PRO MT
    Anyone experience problems with the rear locker not engaging? When I turn on 4Lo and press the locker switch the locker indicator light is red and doesn't stop blinking.
    I searched the forum for previous threads on the issue, but didn't find anything.
    The mechanics at the dealership can't figure it out and next step is Toyota support.
  2. Jun 27, 2017 at 3:12 PM
    Drakedischler1
    Drakedischler1 Well-Known Member
    Houston, TX
    2016 TACOMA TRD OFF ROAD QUICKSAND
    3" LIFT , 305 70 16 TIRES
    That is pretty rare , but should be covered under power train .
  3. Jun 27, 2017 at 3:23 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    1/4 blinks or 1/2 second blinks?
  4. Jun 27, 2017 at 8:26 PM
    TacoWave
    Adam
    2017 PRO MT
    Got it. I hope it is covered.
    Not sure on the exact timing, but it's not rapid blinking, 1/2 second blinks possibly. Do you have an idea on what's wrong either way?
  5. Jun 27, 2017 at 8:44 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    locker will only engage at 5mph or less while in 4low. Sometimes it takes a second or 2 or even 10 to engage but the vehicle should be moving to help align everything up internally. One "trick" that I have read at other forums is to turn in a full circle in both directions to help engage the locker, does that actually help? I dont know
  6. Jun 27, 2017 at 8:45 PM
    hookembevo
    hookembevo Well-Known Member
    Austin, TX
    2016 Tacoma DCSB with 6MT
    Snugtop Rebel with some options Body Armor Rock Steps Rhino Mats Weathertech Mudflaps Radar detector hardwired to rear view mirror. Stereo upgrade: Amp: Arc Audio XDI805 LOC: AudioConnect LC7i Front Speakers: Hybrid Audio Technologies Claris 6.5 Rear Speakers: Hybrid Audio Technologies Mirus 5.25 Sub: Pioneer TS-SW2502S4 Box: Pioneer Ud-SW250T Bilstein 5100s OME 885 Springs Single Add-A-Leaf BFG KO2 265/75/16
    sometimes you have to drive it a few feet forward and stop. if that doesn't work, drive it backwards and stop. turn the wheel back and forth. it'll kick in.
    Jessrin likes this.
  7. Jun 27, 2017 at 8:47 PM
    Thunder Fist
    Thunder Fist Well-Known Member
    David
    Birmingham, AL
    2017 MGM TRD OR DCSB
    Like, so many.
    That seems like a lot of work. I mean, what if you are on a hill and suddenly need your locker?
    tcjacado likes this.
  8. Jun 27, 2017 at 8:50 PM
    MonkeyProof
    SoCal- SGV
    you would have to excuse yourself from the group and do circles somewhere, hopefully there won't be any Jeeps around because you'll never hear the end of it for sure...
  9. Jun 27, 2017 at 8:50 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    If you need your locker chances are you are spinning. No problem.
    1bad2k likes this.
  10. Jun 27, 2017 at 8:51 PM
    Thunder Fist
    David
    Birmingham, AL
    Like, so many.
    Right, but I can't be running around in circles and what not.
  11. Jun 27, 2017 at 8:51 PM
    Ice Horse
    Ice Horse Stalking horse
    Lauren
    Florida
    Two 1998’s and a 2025. All TRD Offroads.
    ADS Racing Shocks 2.5" Extended Travel Coilovers with Reservoirs, 3 inch All Pro rear suspension kit, factory E-locker, Trail Gear sliders and front stinger bumper, CBI Offroad rear tube bumper, XRC8 Winch, 33 inch BFG KM2's, 16 inch Ivan Stewart Wheels, Uniden CB radio, flip up license plate, white tail lights, LED front signals, Tundra front brake upgrade, new radio, rock lights, sub woofer, remote start, satoshi grille with Prius emblem, Rigid DOT/SAE Fog Lights, 12" Light Bar
    At that point, you're probably spinning tires anyway if you need it on. So spinning tires = moving. I've never heard of doing circles but generally if I move forward or backwards a little it will kick on.
  12. Jun 27, 2017 at 8:52 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Hit it with a hammer,and it will engage.
    TacoWave[OP] and tcjacado like this.
  13. Jun 27, 2017 at 8:53 PM
    Jessrin
    Jessrin Oh, okay...
    Jesse
    Upper Michigan
    24 Tacoma Double Cab TRD Off Road 4X4
    Stock
    To me. Your being to gentle. Go out and use it. On a trail or hill. One wheel will slowly spin and she'll lock in. Go out and have fun
  14. Jun 27, 2017 at 8:58 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Again, you are most likely in a low traction condition. Cutting your wheels left then right while spinning is the same as going in a circle under normal traction conditions.
    Judging by some of the comments here not many of you have had to engage a locker nor been in a situation where one is needed.
    Moving forward or backward a bit (or spinning) and cutting your wheels (or going left or right for a bit) are extremely common methods for getting a locker to engage.
    Thunder Fist[QUOTED] likes this.
  15. Jun 27, 2017 at 9:10 PM
    TacoWave
    Adam
    2017 PRO MT
    Thanks for all the feedback.
    I was sure the locker should engage on demand.
    Driving forward in 4Lo and locker switch on doesn't force it to lock. Haven't tried reversing. Seems from what you all are writing is that it takes some persuasion to engage. Might not be worth having the dealer continue working on it.
  16. Jun 27, 2017 at 9:20 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    It does take a bit of finesse. I suggest you look at a simple diagram at how a locker engages on Google. You will quickly see why you have to move or spin a bit to get it locked in.
    TacoWave[QUOTED][OP] likes this.
  17. Jun 27, 2017 at 9:26 PM
    Thunder Fist
    David
    Birmingham, AL
    Like, so many.
    Not air lockers though, right?
  18. Jun 27, 2017 at 9:33 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Still takes a bit for alignment. Sometimes, everything is just right and it just pops in immediately. Other times it takes an act of Congress. Funny thing is locker design is the same now as it was 30 years ago. Same problems then as now lol.
  19. Jun 27, 2017 at 9:38 PM
    hookembevo
    Austin, TX
    And just like 30 years ago, those problems pale in comparison with not having lockers when you need them. :)
  20. Jun 27, 2017 at 9:40 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Are you trying in neutral?
