Rear locker question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AmericanDrug, Feb 17, 2018.
  1. Feb 17, 2018 at 11:01 AM
    AmericanDrug
    AmericanDrug [OP] Well-Known Member
    Rod
    Valdosta, GA
    2018 TRD OR 4x4 6mt
    So I've read the manual and attempted use of the locker. Manual reads when the symbol is solid locker is engaged. My question is does there have too be slippage for the rear locker to engage? In my short testing it out I was off-road but no tire spin and symbol only blinked. First locker I've had if curious...
  2. Feb 17, 2018 at 11:05 AM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    Turn your wheel back and forth while moving slowly forward and backwards.
    Kurupt_hawaiian likes this.
  3. Feb 17, 2018 at 11:19 AM
    AmericanDrug
    Rod
    Valdosta, GA
    2018 TRD OR 4x4 6mt
    Will that help it engage? I've read on it a little bit but does there have too be wheel slip to engage?
  4. Feb 17, 2018 at 11:23 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Did you put it in 4x4 mode first?
    wilcam47 and shakerhood like this.
  5. Feb 17, 2018 at 11:27 AM
    LaRue Shooter
    LaRue Shooter "Keep your dick in a vise."
    Southern Cal
    Built up, locked 06 Sport Access Cab
    Trijicon sticker on rear window.
    Sometimes you have to rock the truck back and forth. When I had the E-locker I got into the habit of pressing the button, putting the truck in reverse and letting it roll back a couple feet, then proceed forward and it would lock every time.
  6. Feb 17, 2018 at 11:28 AM
    AmericanDrug
    Rod
    Valdosta, GA
    2018 TRD OR 4x4 6mt
    Yes 4lo
    Tocamo likes this.
  7. Feb 17, 2018 at 12:04 PM
    Friedtacolover
    Friedtacolover Well-Known Member
    Travis
    Ontario, Ca
    2017 DCSB Off Road 4x4
    my build tread: https://www.tacomaworld.com/threads/socal-no-shame-poser-build.513084/
    My locker is a PITA to engage and also to disengage from 4lo. Grinded the hell out of it last week
  8. Feb 17, 2018 at 12:17 PM
    AmericanDrug
    Rod
    Valdosta, GA
    2018 TRD OR 4x4 6mt
    That's exactly why I was using it. Keep a habit of using it and lube everything in 4wd up.
    DoorDing likes this.
  9. Feb 17, 2018 at 12:17 PM
    Friedtacolover
    Travis
    Ontario, Ca
    What do you find is the best way to engage 4lo and the locker? Cause im having a hell of a time out there. I cant remember exactly what i did but i think i put it in nuetral and engage it then rock forward and back.
  10. Feb 17, 2018 at 12:20 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    I believe its got to be in neutral to go into 4lo then engage the lock. It will only flash in 4hi and not lock.
  11. Feb 17, 2018 at 12:26 PM
    Drunken Chewbacca
    Drunken Chewbacca Well-Known Member
    Josh
    3rd Gen Taco
    Not enough to list
    Mine goes in butter smooth. I'd get that checked out
  12. Feb 17, 2018 at 1:57 PM
    AmericanDrug
    Rod
    Valdosta, GA
    2018 TRD OR 4x4 6mt
    Yea same recommendation on third gen. To lube properly
  13. Feb 17, 2018 at 10:16 PM
    shackley
    shackley Well-Known Member
    Albuquerque, New Mexico
    2018 TRD Pro MT Super White
    RCI rock sliders, Goodyear Ultraterrains 265/70/R16, BAK X2 tonneau
    Toyota says to exercise it every month.
  14. Feb 17, 2018 at 10:25 PM
    Simpleton
    Simpleton Well-Known Member
    Orange County
    2017 DCSBOR
    None as of yet
    drive in a ~ shape for a little bit. The lock needs to be aligned and then it will lock once it gets there.
