Rear locker questions....
Discussion in '1st Gen. Tacomas (1995-2004)' started by Fallguy6666, Oct 11, 2015.
  1. Oct 11, 2015 at 9:27 PM
    Fallguy6666
    Fallguy6666 [OP] Well-Known Member
    Went wheeling over the weekend....my verdict....I need a rear locker!!! Besides the e-locker conversion, what do you guys run? Mine is a 97' 2.7 4x4.I will weld the rear diff if necessary....
  2. Oct 11, 2015 at 9:28 PM
    Fallguy6666
    My bad....the cheaper the better.I wish I could afford an arb.
  3. Oct 11, 2015 at 9:31 PM
    TheStevo
    TheStevo Baja Taco Enthusiast
    Stevo
    Reno, NV
    MAGNETO
    TC +3.5 LT, Fox COs, King Bypasses, DTF SUA w/ 3x18 Quad bypass, Fox Air Bumps, Method 17" NVs, 35s, Relentless Fab custom tube bumper, skids, & sliders, lots of LEDs
    Could do a detroit locker
  4. Oct 11, 2015 at 9:31 PM
    Fallguy6666
    What do you mean by not street friendly?
  5. Oct 11, 2015 at 9:34 PM
    Fallguy6666
    I can deal with that.
  6. Oct 11, 2015 at 9:40 PM
    TheStevo
    Stevo
    Reno, NV
    MAGNETO
    Detroit locker is half the price of an ARB, although I'm not sure they make one for 1st gen rear...
  7. Oct 11, 2015 at 9:41 PM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    I hope that this is purely and off-road rig because that's a little dangerous.
  8. Oct 11, 2015 at 9:43 PM
    Yota64
    Yota64 Professional Threadjacker
    I wouldn't use an any-time locker on the road. It locks up when throttle is applied, if my research serves me well. Luckily I stumbled upon an e-locker axle and have performed the swap with friends. Can't wait to use it and not get stuck in the wet grass.
  9. Oct 11, 2015 at 9:50 PM
    Phoenix autoworks
    Phoenix autoworks Stock but fun!!!
    Josh
    North Phoenix
    95.5 Tacoma 4x4 3.4 manual
    Stock but I use it anyway!!!
    Is there a kit/mod to give my 1st gen the locking rear if I don't already have it? If not any recommendations? ARB?
  10. Oct 11, 2015 at 10:38 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Detroit does make a locker and a gear-driven LSD for the 1st gens. I have the LSD (aka TruTrac).
  11. Oct 11, 2015 at 10:50 PM
    mountainwolfpup
    mountainwolfpup Ford Guy (Formerly known as a Toyota Guy)
    Vancouver, WA
    2015 Ford F150 Lariat FX4 3.5l Eco
    First month of ownership... This month I'm removing front air dam, and also Rhino lining the bed.
    Might want to consider a good limited slip instead of a locked dif. They are really the best all-around solution.
    For a locker I'd only put an ARB on my truck, besides the factory eLocker that I have now. And the loss of limited slip with a locker is a bummer since I spend almost 90% of my drive time on road.
  12. Oct 11, 2015 at 10:57 PM
    Yota64
    Agreed, LSD is good and safe on-road whereas lockers are only usable when turned on. I would definitely use an LSD and whatever the e-brake trick is to make it work instead of a full time locker.
  13. Oct 12, 2015 at 1:14 AM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    I wouldnt weld the diff...a full time locked rear is a bitch for handling, a little unsafe in slippery conditions(eventually it would bite you in the ass no matter how good of a driver you are, youd swap ends at some point especially in packed snow/ice conditions) and very hard on components and tires when turning in situations with plenty of traction (which is 98% of the time) a selectable locker is ideal but if the $$ is a problem...well...thats a problem. I run the arb, if i didnt have that i would want the toyota e-lock. If those arent an option for you a lsd like the true track mentioned above would be the next best thing. But really a selectable is the way to go and if you go air locker youve now got on board air which is super super nice to have, especially for airing up tires incase of a puncture or if youve aired down when in a wheeling situation...
    Yota64 likes this.
  14. Oct 12, 2015 at 6:25 AM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    Powertrax no-slip. Much more street friendly and virtually silent. I installed myself and have 20k on it with no issues. Install is much easier/cheap than an arb or detroit.
  15. Oct 12, 2015 at 8:03 AM
    tan4x4
    Rick
    Folsom, CA
    Thats the 'backwoods' solution . . . . cheap and stupid :rolleyes:
  16. Oct 12, 2015 at 8:04 AM
    Phoenix autoworks
    Josh
    North Phoenix
    I've never met anyone who had luck with or liked their welded rear end. They all regretted it.
  17. Oct 12, 2015 at 8:30 AM
    Balockay
    Balockay Well-Known Member
    Blake
    Cleburne, TX
    2017 4Runner TRD ORP
    Just look at the build thread
    I've had a LockRight and an ARB. Go with the LockRight. I couldn't tell any difference on the road with the LockRight as compared to stock other than some noise. ARB is nice to be able to turn it off and on but too many parts that could potentially fail. You have all the electrical and all the pneumatic parts to maintain. Compressor, airlines, actuator, wiring, switches... All those parts can fail potentially leaving you stranded somewhere.
  18. Oct 12, 2015 at 9:03 AM
    tan4x4
    Rick
    Folsom, CA
    This is a good choice, if the advertisements are true. Its the least expensive way to gain real traction.
    However, almost any non-selectable locker could be a liability in icy conditions. I remember one time on an icy incline, where the locked truck in front of me slid all over and couldn't make it up. I made it up with my clutch-type LSD.
    Devinzz1 , I notice you live in the 'frozen north'. Has this been an issue with you?
  19. Oct 12, 2015 at 12:01 PM
    chowwwww
    chowwwww Well-Known Member
    Orange County
    03 Doublecab 4x4
    Billys 5100/Eibach and Wheelers Progressive 1.5 AAL with overload in
    Was also looking into the Powertrax No-slip. Live in SoCal and not that many icy roads here so I am not too worried about ice.
  20. Oct 12, 2015 at 12:57 PM
    devinzz1
    devin
    2023 aclb trd or mt
    Trust me. This locker is better in snow/icy conditions than a good clutch type lsd. In slippery conditions the clutched lsds seem to not "slip". With the no slip as soon as you let off gas it unlocks (you can unlock the diff and spin tire with nothing but your pinky)
    MindFork likes this.
