Rear locker use.......
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Casper3225, Jan 3, 2012.
  1. Feb 1, 2012 at 8:18 PM
    #41
    Utard
    Utard Well-Known Member
    Mark
    Nyssa, Oregon
    2012 DC LB 4WD TRD SPORT NAVI
    ------------------------------------------------------------ Stabilus.EZDown.Tailgate http://www.ezdown.com/home.php ----------------------------------------------- Tekonsha.Primus.IQ.Trailer.brake http://www.tekonsha.com/content/default.aspx---------------------------------------------------------------- Leer 180 CC http://www.leer.com/Truck-Caps#------------------------------------------------ Firestone Air Rite Air Bags--------------------------------------Kargomaster Rack
  2. Feb 1, 2012 at 8:35 PM
    #42
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    i once forget to get out of 4H after a nice easy trail run and drove home on the freeway approx 45 miles to get back home. i stopped at a starbuck on the way and noticed some binding as i was trying to fit into a parking spot:rolleyes:
  3. Feb 1, 2012 at 8:41 PM
    #43
    Utard
    Mark
    Nyssa, Oregon
    Well I did 100 in 4LO up hill both ways in the middle of the night!
  4. Feb 1, 2012 at 8:41 PM
    #44
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    'Ello good peeple! :wave:
  5. Feb 1, 2012 at 8:43 PM
    #45
    MonkeyProof
    SoCal- SGV
    :lalala:
  6. Feb 1, 2012 at 8:46 PM
    #46
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  7. Feb 1, 2012 at 8:48 PM
    #47
    MonkeyProof
    SoCal- SGV
  8. Feb 1, 2012 at 8:49 PM
    #48
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  9. Feb 1, 2012 at 8:50 PM
    #49
    MonkeyProof
    SoCal- SGV
    HAHAHHAHAHAHHAHHAHAHAHHAHAHAHHAHAHHAHAHAHHAHAHHAHAHHAHHAHAHHAHHHAHAHAH
  10. Feb 1, 2012 at 8:57 PM
    #50
    Taqoma
    Taqoma Well-Known Member
    Brennan
    Los Angeles
    2011 TRD Off-Road
    TRD Supercharger, TRD CAI, Camburg LT, Fox 2.5x8 coilovers, Fox 2.0 bumps, Deaver e30 leafs, Fox 3.0x18 triples, Avid sliders, Yaesu 2900R, Pro Comp 7089 16x8, DDM 55w HID Hella 500FF, DDM 35w HID headlights, Magnaflow 11255 muffler, PLX DM-100 OBDII, Autometer Ultra-Lite II Boost gauge, Flex Pod gauge mount, LSK tube bumper, McNeil fenders, Fiberwerx bedsides, 285/75/16 Toyo MT's
    https://www.youtube.com/watch?v=1FMQbEzRFKk in this video there's a comment saying,
    "Actually if you go to 4L, engage the diff lock, and then go back into 2WD, the diff will stay locked. I did it once to see if I could in my '00 Tacoma."
    Does this work?
  11. Feb 1, 2012 at 8:58 PM
    #51
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Okay so you didn't blow up your t-case by driving in 4wd on pavement. Regardless something has to give. Usually it's the tires. Could be your t-case, could be a diff, could be a u-joint, could be a yoke, could be anything. That's why it's unadvisable to drive in 4wd on pavement. Doesn't mean you're going to damage something but it's possible.
    Theres also a little slack between all the mechanical connections and the tires so you do get a little give before you start binding things fwiw.
    That link does mention one more thing, even if going straight slight tire differences could create a difference in speed which would cause binding. (back to the differential action and tire differences incurring wear on spiders and cross and carrier but with no differential action we get binding)
  12. Feb 1, 2012 at 8:59 PM
    #52
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    IIRC you can't take it out of 4wd with diff engaged, due to computer.
  13. Feb 1, 2012 at 9:02 PM
    #53
    Taqoma
    Brennan
    Los Angeles
    2011 TRD Off-Road
    sorry, but what's IIRC? :(
  14. Feb 1, 2012 at 9:15 PM
    #54
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    I'd imagine you could leave the locker engaged, unless Toyota has some switch that auto disengages the factory locker when taken out of 4wd, I'm just really not sure. So then technically I think disengaging a locker at speed should be fine as long as you're not putting a huge strain on the locker (like going around a corner locked), at least I think so, but I wouldn't think toyota would have it auto disengage just in case, but I'm really not sure.
    Manual shift lucky!
    IIRC - if I remember correctly
  15. Feb 1, 2012 at 9:43 PM
    #55
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Well then your tires were able to slip, it's not so much the speed as it is the binding. Though I'd imagine high speed would froth the oil and build up a lot of heat breaking down the additives in the gear oil sooner. Syn obviously excels there. I don't think it's really an issue anyway but just threw that out there for arguments sake.
  16. Feb 1, 2012 at 10:08 PM
    #56
    MonkeyProof
    SoCal- SGV
    Soggy Dry Lake Bed in Johnson Valley is hard packed..good luck in driving tent stakes into the ground without bending them:mad:
  17. Feb 1, 2012 at 10:11 PM
    #57
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
  18. Feb 1, 2012 at 10:12 PM
    #58
    Konaborne
    Cody
    Kealakekua, Hawaii
    oh fuck. Its this thread.
    NOOB
  19. Feb 1, 2012 at 10:14 PM
    #59
    MonkeyProof
    SoCal- SGV
  20. Feb 1, 2012 at 10:27 PM
    #60
    deadhed61
    deadhed61 :notsure:
    Santa Barbara, Ca
    The Black Pearl
    A little lift and a little armor
    Kealakekua, Hawaii??? Possibly Makalawena?? :cool:
