rear locker
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 08ruggedtrail, Mar 13, 2010.
  1. Mar 13, 2010 at 4:04 PM
    08ruggedtrail
    08ruggedtrail [OP] Well-Known Member
    shannon
    south carolina
    1991 v6 4x4
    lifted
    i dont think my rear locker is working ? i am not sure but i pressed the button and on my dash the light was blinking and all but both tires were spinning , anyone have any advice ?:confused:
  2. Mar 13, 2010 at 4:05 PM
    surfrat
    surfrat Well-Known Member
    LI, NY
    icon coilover, total chaos UCA, allpr expo, icon 2.0 rear,wet okole
    put it in 4 low
  3. Mar 13, 2010 at 4:08 PM
    Brunes
    Brunes abides.
    Rotorhead
    Yeah....Make sure you are doing everything you need to in order to get the locker to engage.
  4. Mar 13, 2010 at 4:20 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    Get into 4lo, press locker button at under 5mph ( I usually just stop, hit button, and then barely get rolling again to let it engage). When it is engaged the light will stop flashing and just stay on.
    I've found that mine engages real easy now whereas it took longer when I first used it.
    Once it's engaged you can go as fast as you want... but since you have to be in 4lo you shouldn't be going over 10mph anyway imo.
  5. Mar 13, 2010 at 4:29 PM
    BakoTruck
    BakoTruck Well-Known Member
    Herbie Hancock
    Bakersfield, CA
    05 PreRunner TRD
    Mostly stock for now, I have added a cb radio, various cheap mods and I plan on adding aftermarket wheels and other items in the future.
    Also try turning your truck to one side and then move forward, I heard that this helps engage it faster. Haven't tried this yet, I don't have a chance to use my locker all that much.
  6. Mar 13, 2010 at 4:50 PM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    x2
  7. Mar 13, 2010 at 9:14 PM
    08ruggedtrail
    shannon
    south carolina
    1991 v6 4x4
    lifted
    so it can not be used in 2wd ?
  8. Mar 13, 2010 at 9:17 PM
    ttylerr
    ttylerr Well-Known Member
    Tyler
    Fort McMurray, Alberta
    09 MGM 4Banger 4x4
    5% tint all around, Alpine IVA-W505, 16x8 Mojave Teflon Rims w/Hercules Terra Trac 265/75, Grillcraft Grill, Slimcubby HIDs, Front 5100's @ 0 w/Eibach 1.6" springs, URD Short Shifter, Extang Trifecta Tonneau Cover, Uniden Pro510XL and K30Mag Mount, Relentless Fab Bumper soon to come
    not without some modification. search in the cheap/free mods section
  9. Mar 13, 2010 at 9:20 PM
    08ruggedtrail
    shannon
    south carolina
    1991 v6 4x4
    lifted
    ok . thanks for everyones input . i thought it wasnt doing what it should be lol
  10. Mar 13, 2010 at 9:20 PM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    Nope...that's why it was blinking (it wasn't engaged.) Got to be in 4lo.
  11. Mar 14, 2010 at 12:18 PM
    David K
    x2
    There is a mod. with a relay if you want it to work in H2... well described with photos here on TW.
    4WD is the first route for better traction and the rear locker is to be used only if you need additional traction or think of it as a traction aid.
    PreRunners (2WD Tacomas) with the rear locker don't have the luxery of 4WD, so the rear locker is the traction aid.
