Rear Locker
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rschuck, Apr 15, 2010.
  1. Apr 15, 2010 at 5:35 AM
    Rschuck
    Rschuck [OP] Member
    Robert
    Freeport, Tx
    08 Tacoma 4x4
    Toytech Ultimate Lift 18 in Rock Star Wheels 285x65xR18 Nitto Mud Terrian Allpro Front Bumper
    I have an 2008 Tacoma with a limited slip rear end. Am i going to have to change the rear end to make it where it will lock or is there something toyota can add to the electronic to make it lock. I know i have a place on the dash for the factory axle lock button but it is not there. You have to pay extra for that. Now i wish i did but do you guy's have any ideas. I was hoping that the rear end was already set up for the locker but with my luck i will probably have to change the rear end.
  2. Apr 15, 2010 at 5:44 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    If you want a toyota e-locker, you will need to swap out the rear ends, plus, plus. Big job. Or, you can just install an ARB Locker, and you will end up with a selectable locker with a stronger rear end then the factory e-locker. And, thru the end of month, if you buy a ARB locker you will recieve a air compressor for free. :cool:
  3. Apr 15, 2010 at 6:34 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    ARB is probably best way to go as somebody mentioned, but why do you need to change it? Whats wrong with LSD?
  4. Apr 15, 2010 at 6:46 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
  5. Apr 15, 2010 at 7:10 AM
    BlueT
    NorthEast
    huh what that supposed to mean :confused: :)
  6. Apr 15, 2010 at 7:23 AM
    cameronlane
    cameronlane Well-Known Member
    cameron
    Anywhere but there
    2014 Dbl Cab TRD OR 4x4
  7. Apr 15, 2010 at 7:51 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    never been there but from that Im assuming people dont like to help?
    I was however helping, this is a well talked about topic and the OP seems to know very little about the subject. I was just pointing him in the right direction for some info before getting another thread into one that his questions probably have already been answered.
  8. Apr 15, 2010 at 7:56 AM
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    Don't worry about it Keason. Guys seem to be getting VERY sensitive on here lately.
  9. Apr 15, 2010 at 7:58 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Keep the LSD.
    If you want/need a locker..... put an ARB in the front and have the best of both worlds.
  10. Apr 15, 2010 at 7:59 AM
    Crom
    Crom Outside
    Nick
    San Diego, CA
    2009 4x4 DCSB Overland Build
    Millions
    To the OP, while my solution may seem drastic to you, consider the options of trading your truck for a 2009 or 2010 4x4 with the TRD Off Road package.
    You will get your factory rear locker, and to boot you will have A-TRAC. With those tools in the bag it is difficult to get stuck. If there is traction to be had, even if it's only one wheel you will get free.
  11. Apr 15, 2010 at 5:00 PM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    DITTO what Crom says!
  12. Apr 15, 2010 at 10:21 PM
    Janster
    Jandy
    Lancaster, PA
    You can grenade your CV's turning too tightly in 4WD without a locker.
    Using a locker in the front - no matter what axle you have, you've gotta use it wisely and responsibly. The one thing everyone should know about having lockers in the front, is you can't turn tight with them.
    You really shouldn't be using a front locker unless you really need it.
  13. Apr 15, 2010 at 10:28 PM
    jefferson
    jefferson needs to stop cruising Buy/Sell/Trade....
    Sex Panther
    San Diego (North Park!), CA
    05 PreRunner SR5
    toyota brand hitch and uhaul wiring harness, fog lamps on anytime, bed lamps, map lights on with dome, day time running lamps, remove secondary air filter, painted bumper grill, Double Din touch screen stereo, Sockmonkey custom SR5 decal, door & seatbelt bells disabled, painted engine cover, installed compass/temperature overhead console, failed mod: passenger side auto down window switches, weathertech front mats, RedLine hood struts, Cheap Beep piezo buzzer locking beep, 5100s in the front set at 2.5, 5100s in the rear, AAL, hitch safe, revenge fab sliders, bed bar, prerunner light, cb wired
    wish i had the 800+ for an ARB rear locker...
  14. Apr 16, 2010 at 6:36 AM
    Janster
    Jandy
    Lancaster, PA
    Not necessarily for the OP (since he's from Texas) - but for people who live in the snow belt need the mechanical LSD for the daily driving in the winter.
    It was just an 'option' for the OP to think about. Not knowing what types of trails he does - the front locker would probably be fine for most situations. And if he's getting himself into harder trails where the ARB won't be a benefit (based on steering), then its time to think about getting a winch.
    Nobody ever said you had to utilize a front ARB in every situation. If you're in a situation where you could blow the axles, then pull cable and move on.
    Personally for me, I like having the mechanical LSD for the winter.
